Hi! I haven't decided yet between BV 10-46 and BV 11-46, but a question arises: how will I connect my beosound 9000 to it?
BV10 have masterlink input but what about BV 11? I looked in its guide but I didn't find out.
Thanks!
Liviu
There is a converter but it's quite expensive (and complex). I guess if Masterlink is important and you're not interested in all of the improvements of the BV11 then you could probably get a fairly bargain price on a 10-46 as it's now a deprecated model.
http://archivedforum2.beoworld.org/forums/t/3006.aspx?PageIndex=1
Page 57 - http://www.bang-olufsen.com/en/customer-service/product-support/picture/beovision-11
Get the BV11 and the converter - fit for the future
Grrr Millemissen
