BV 11 - does it have masterlink?
liviu_o
Posts 157
liviu_o Posted: Mon, Oct 22 2012 5:43 PM
Hi! I haven't decided yet between BV 10-46 and BV 11-46, but a question arises: how will I connect my beosound 9000 to it?
BV10 have masterlink input but what about BV 11? I looked in its guide but I didn't find out.
Thanks!
Liviu
jkhamler
Posts 286
jkhamler replied on Mon, Oct 22 2012 5:50 PM
There is a converter but it's quite expensive (and complex). I guess if Masterlink is important and you're not interested in all of the improvements of the BV11 then you could probably get a fairly bargain price on a 10-46 as it's now a deprecated model.
Millemissen
Flensborg, Denmark
Posts 14,680
http://archivedforum2.beoworld.org/forums/t/3006.aspx?PageIndex=1
Page 57 -  http://www.bang-olufsen.com/en/customer-service/product-support/picture/beovision-11
Get the BV11 and the converter - fit for the future Smile
Grrr Millemissen
Raeuber
Germany
Posts 2,542
Raeuber replied on Mon, Oct 22 2012 5:52 PM
Hi Liviu,
as already discussed here, the BV 11 has NO masterlink anymore.
If you want to connect your BS 9000, you need the new NL/ML-converter (700 EUR!).
Or go for a BV 10, if your dealer makes a good offer (because BV 10 will be discontinued).
Regards
Räuber
Page 1 of 1 (4 items) | RSS
