PowerLink>Ethernet adapter availability?
This post has 8 Replies | 0 Followers
mbee
Paris, France
Posts 1,842
mbee Posted: Wed, Mar 7 2012 3:48 PM
I've seen somewhere on what is now called the "archivedforum", that B&O has a small cable accessory which allows to adapt Powerlink to ethernet cables.
As my new flat has some ethernet cables inside the walls, this adapter would be ideal for my rear speakers. I've asked my dealer and he said "not available". As it's only a bit of cable (that I can do myself if it's really not available), can someone confirm that this is not available? Steve at Soundsheavenly doesn't have it in its listing too, but he surely can make it!
Otherwise, maybe someone can give me the product code (to give it to my dealer), and... The price (if it's too expensive, I think that I can make it myself)!
mbee
Paris, France
Posts 1,842
mbee replied on Thu, Mar 8 2012 11:07 PM
Nobody??
wesheltonj
Texas
Posts 22
I think it will have to be custom made right now.  However, if it not CAT7 in the wall, it will not work, correctly.
BeoSystem 5500, BeoVision 10-46, BeoLab 8002
Apple TV
Samsung BD-D7500
Wii
Vienna
make an educated guess
Posts 1,090
Vienna replied on Fri, Mar 9 2012 12:33 AM
mbee:
LOL ! Maybe the original B&O Item (Order) Numbers will help your "dealer"
6270017 for 1,5m RJ45<>DIN 8pin black
6270020 for 3,0m RJ45<>DIN 8pin black
6270004 for 5,0m RJ45<>DIN 8pin black
6270022 for 10m RJ45<>DIN 8pin black
Cables also available in white,
Retail prices from approx 20 to 40 EUR
Keep in mind that the cables in the wall need to be CAT 6 or CAT 7 and they have to be S/FTP type
cables (= Screened/Shielded cable with separately Foiled Twisted Pairs)
PS:
Keep in mind that you can use CAT 6/7 cables as a replacement for PL-Cables only in a "passive" way
"point to point" - no switches / routers are  allowed between the PL-out of the TV and the PL-in of your speaker.
Browse in the old forum the topics "NIC" "Network Link" "New Installation Concept" "BeoNet" ...
valve1
The south of France and occasionally Dublin Ireland
Posts 1,502
valve1 replied on Fri, Mar 9 2012 7:18 AM
I am guessing the cat cable is either daisy chained around the rooms or wired to a central point. If you cannot use it, why not "tie on and pull in" the correct cable?
mbee
Paris, France
Posts 1,842
mbee replied on Sun, Mar 11 2012 10:47 PM
Thanks Vienna for the item numbers : it shows again that it's really difficult to find a good dealer Wink
And thanks valve1, I think I will just pull in a powerlink cable through the wall, there is some space remaining in the tubes...
PS : why should the ethernet cable be CAT6/CAT7 cables and S/FTP, as I'm quite sure a standard Powerlink cable doesn't meet this level of specifications??? That seems to be cable mythology... Cool
Vienna
Posts 1,090
Vienna replied on Mon, Mar 12 2012 1:03 AM
mbee:
No myth - it's the shielding, not the bandwidth, that counts in the "analogue world" of PowerLink and MasterLink ...
A standard Cat 5 or 5e cable has no shielding between the twistet pairs an will very likely pick up hum etc. on
longer distances.
B&O urges the use of CAT 7 as these cables are always S/FTP types and fulfill, if properly done, all shielding
reqirements perfectly ...
mbee
Paris, France
Posts 1,842
mbee replied on Mon, Mar 12 2012 6:53 AM
As far as I know, the powerlink cables have only an outside shielding, and no shielding between the pairs... Or maybe it was an old model that I "dismantled".
Vienna
Posts 1,090
Vienna replied on Mon, Mar 12 2012 8:26 PM
mbee:
Recent PL-cables have a diameter of approx 5mm and are double shielded.
Exeption is the thin 2,6mm MK3 version for short distances.
The discontinued 3,5 mmm fully mounted MK2 cable also had separate schielding
for audio and PL-data to avoid crosstalk between audio and PL-data.
Page 1 of 1 (9 items) | RSS
DigiCert Secured Site Seal
