Hi all,
What center speaker should be preferred for a 5.1 setup with
BL17 (Rear)
BL18 (Front)
BL19 (Sub)
The idea is to use the above speakers wireless with transmitter 1 and an Marantz AV7704.
Centre could be both wired and wireless.
BR Micke
BeoLab 10 / BeoLab 7-6
Peter Pan: BeoLab 10 / BeoLab 7-6
Beolab 10 is not an option unfortunately due to the design is not approved by my partner.
I've found an Beolab 7.4 for 290€.
What is the difference between a Beolab 7.4 and 7.6?
Any other options?
BR
Micke
That is the exact setup I have using a Marantz AV receiver, only difference is that I use bL 15 built into the ceiling as rear speakers, and
I use a Definitive technology center speaker which has a built in sub woofer as well and it works marvelously
Good luck
Thanks, I ordered the 7.4.
Now I have the problem to find a good media cabinet/furniture.
Today I have a white cabinet 200/42/35cm (length/width/height) hanging 15cm from the floor.
Would like a similar setup with 2x media cabinets with approx 80/40/35cm measure and have the BL 7.4 in the middle.
Have not found any good media cabinets to use or adapt yet.
Hallo MavvenCabinet - furniture. / Peter Pan
Peter Pan: Hallo MavvenCabinet - furniture. / Peter Pan
Many thanks!
leogoeswild:What tv do you have? I made a bracket for an old BV7 stand, works perfectly π
A samsung 75 inch tv. My idea is to have it like this, see illustration attached.
So far I cannot find find any cabinets that I can hang on the wall that are
length: 80-90cm
Height: ~35cm
Depth: min 45 cm (inside).
I like the style of Clic.
leogoeswild:You could get a BV7-32 or 42 stand and mount the screen on it. Here is a picture of my 55” Samsung on a stand. You would get the tilt and turn function also, manually of course.
Clever and looks nice! My tv is already wall mounted though. It's the cabinets that I need to find to fit the reciever and other electronics
Seems like I will have to build one myself. However I rather buy to save time.
Hello again Mavven
So, this is what you must have.
Regards Peter Pan
Peter Pan: Hello again Mavven So, this is what you must have. Regards Peter Pan
Wow, exactly! Is it your setup and what cabinet manufacturer?
Mavven:Wow, exactly! Is it your setup and what cabinet manufacturer ?
Hallo Mavven
There are DIY cabinets so you decide what to contain.
Peter Pan: Mavven:Wow, exactly! Is it your setup and what cabinet manufacturer ? Hallo Mavven There are DIY cabinets so you decide what to contain.
I've decided for 2x white Clic 212 Large cabinets with light grey fabric doors. I will modify them inside for extra air flow and heat transfer. Will fit transmitter 1, av reciever, media computer, bluray player and PS4.
