Center speaker for BL17,18,19 setup
This post has 16 Replies | 0 Followers
Mavven
Posts 15
Mavven Posted: Sat, May 26 2018 10:06 AM
Hi all,
What center speaker should be preferred for a 5.1 setup with
BL17 (Rear)
BL18 (Front)
BL19 (Sub)
The idea is to use the above speakers wireless with transmitter 1 and an Marantz AV7704.
Centre could be both wired and wireless.
BR Micke
Peter Pan
Posts 2,088
Peter Pan replied on Sat, May 26 2018 10:22 AM
BeoLab 10 / BeoLab 7-6
Mavven
Posts 15
Mavven replied on Sat, May 26 2018 11:59 AM
Peter Pan:
Beolab 10 is not an option unfortunately due to the design is not approved by my partner.
I've found an Beolab 7.4 for 290€.
What is the difference between a Beolab 7.4 and 7.6?
Any other options?
BR
Micke
Tifoso48
Posts 162
Tifoso48 replied on Sun, May 27 2018 4:48 AM
That is the exact setup I have using a Marantz AV receiver, only difference is that I use bL 15 built into the ceiling as rear speakers, and
I use a Definitive technology center speaker which has a built in sub woofer as well and it works marvelously
Good luck
leosgonewild
Helsinki, Finland
Posts 2,373
Beolab 7.4 is a center speaker and it is made specifically for that, especially when you have a full surround setup.
Beolab 7.6 is a stereospeaker. It can be used as a center speaker.
Go with the 7.4. It’s a great speaker Big Smile
Mavven
Posts 15
Mavven replied on Sun, May 27 2018 6:12 PM
Thanks, I ordered the 7.4.
Now I have the problem to find a good media cabinet/furniture. ConfusedSmile
Today I have a white cabinet 200/42/35cm (length/width/height) hanging 15cm from the floor.
Would like a similar setup with 2x media cabinets with approx 80/40/35cm measure and have the BL 7.4 in the middle.
Have not found any good media cabinets to use or adapt yet.
Peter Pan
Posts 2,088
Peter Pan replied on Mon, May 28 2018 6:17 PM
Hallo Mavven
Cabinet - furniture.
/ Peter Pan
Mavven
Posts 15
Mavven replied on Wed, May 30 2018 1:29 PM
Peter Pan:
Hallo Mavven
/ Peter Pan
Many thanks! Smile
leosgonewild
Helsinki, Finland
Posts 2,373
What tv do you have? I made a bracket for an old BV7 stand, works perfectly πŸ˜€
Mavven
Posts 15
leogoeswild:
A samsung 75 inch tv. My idea is to have it like this, see illustration attached.
So far I cannot find find any cabinets that I can hang on the wall that are
length: 80-90cm
Height: ~35cm
Depth: min 45 cm (inside).
I like the style of Clic. Smile
leosgonewild
Helsinki, Finland
Posts 2,373
You could get a BV7-32 or 42 stand and mount the screen on it.
Here is a picture of my 55” Samsung on a stand.
You would get the tilt and turn function also, manually of course.
Mavven
Posts 15
Mavven replied on Wed, May 30 2018 8:39 PM
leogoeswild:
Clever and looks nice! My tv is already wall mounted though. It's the cabinets that I need to find to fit the reciever and other electronics Smile
Seems like I will have to build one myself. However I rather buy to save time.
leosgonewild
Helsinki, Finland
Posts 2,373
A floating wall is also an optionSmile
Peter Pan
Posts 2,088
Peter Pan replied on Thu, May 31 2018 3:12 PM
Hello again Mavven
So, this is what you must have.  Idea
Regards Peter Pan
Mavven
Posts 15
Mavven replied on Thu, May 31 2018 4:27 PM
Peter Pan:
Hello again Mavven
Regards Peter Pan
Wow, exactly! Is it your setup and what cabinet manufacturer?
Peter Pan
Posts 2,088
Mavven:
Wow, exactly! Is it your setup and what cabinet manufacturer ?
Hallo Mavven
There are DIY cabinets so you decide what to contain. Yes - thumbs up
Mavven
Posts 15
Mavven replied on Sat, Jun 2 2018 11:40 AM
Peter Pan:
Mavven:
Hallo Mavven
I've decided for 2x white Clic 212 Large cabinets with light grey fabric doors. I will modify them inside for extra air flow and heat transfer. Will fit transmitter 1, av reciever, media computer, bluray player and PS4.
Page 1 of 1 (17 items) | RSS
