I have installed the BeoPort in my system with the latest BeoPort software. Several years ago when I have played with the similar unit, the product asked for the registration e-mail and after that I could get the access to the N.Radio resources. This time it does not ask anytjing, and N.Radio says "Not registered".
There are some differences in the installations. Previously, BeoPort was the only device, and now I also have BeoSound 5 in the Masterlink (My BS5 radio named Radio in the Masterlink, not N.Radio, so it is not the naming issue) but I suspect that it is somehow related with the end of support as discussed here.
Do you know how to check to be sure?
https://beointegration.wordpress.com/
1:BV7+BL7.1+BS4+BL6000+BV6+BL2000+MLGW+Beo4
2:BV7+BL7.4+BL3500+BM5+BL3+Lutron GE/Sivoia QS+HikVision+Dune+LinTronic+BLGW+Beo4+Beo5+Essence remote+BeoTime+BeoLinkPC+BL4+KNX+... BeoMaster900
Aleksei:Hi, I have installed the BeoPort in my system with the latest BeoPort software. Several years ago when I have played with the similar unit, the product asked for the registration e-mail and after that I could get the access to the N.Radio resources. This time it does not ask anytjing, and N.Radio says "Not registered". There are some differences in the installations. Previously, BeoPort was the only device, and now I also have BeoSound 5 in the Masterlink (My BS5 radio named Radio in the Masterlink, not N.Radio, so it is not the naming issue) but I suspect that it is somehow related with the end of support as discussed here . Do you know how to check to be sure? https://beointegration.wordpress.com/
BeoNut since '75
