Beogram 900 RG stereo issue with record deck
nickcoffer
Posts 5
nickcoffer Posted: Thu, Jun 7 2018 12:01 AM
Good evening everyone...
So I somehow miraculously got the record deck to work again in my Beogram 900 RG de luxe. It's a Garrard AT6 deck and was dead when I bought the unit.
I finally got the motor to work, bought a new stylus, and I am almost there.
The only problem is when I play a record in stereo mode, it only comes out mainly from the right speaker. Put it through mono and it comes out through both.
I have checked the input etc, by linking up my MacBook using a DIN plug cable. That works perfectly. Lovely stereo, perfect balance.
So I have eliminated the issue being with the connectors or with the amp.
This leaves possibly:
The cartridge?
The cable from the pre-amp to the amp?
The pre-amp itself?
Something else in the record player?
I have found quite a few posts reporting this problem but they either remained unresolved or the suggested solutions were so diverse as to be difficult to follow.
I am so close to getting this beautiful kit fully back up and running! Any help would be massively appreciated.
Thanks so much.
Nick
Andrew
Frinton, UK
Posts 917
Andrew replied on Fri, Jun 15 2018 10:53 AM
Can you test the cartridge on a different deck? If it’s the same deck I am thinking of the head shell is removable so you could check that - I have an sp25 MKii in a hacker and found once just removing it and cleaning the contacts sorted out crackle - also you could try swapping the leads to the cartridge round and that the in you get sound from the other side it is likely to be a duff cartridge - if no sound then it’s further up the line?
Page 1 of 1 (2 items) | RSS
