Good evening everyone...
So I somehow miraculously got the record deck to work again in my Beogram 900 RG de luxe. It's a Garrard AT6 deck and was dead when I bought the unit.
I finally got the motor to work, bought a new stylus, and I am almost there.
The only problem is when I play a record in stereo mode, it only comes out mainly from the right speaker. Put it through mono and it comes out through both.
I have checked the input etc, by linking up my MacBook using a DIN plug cable. That works perfectly. Lovely stereo, perfect balance.
So I have eliminated the issue being with the connectors or with the amp.
This leaves possibly:
The cartridge?
The cable from the pre-amp to the amp?
The pre-amp itself?
Something else in the record player?
I have found quite a few posts reporting this problem but they either remained unresolved or the suggested solutions were so diverse as to be difficult to follow.
I am so close to getting this beautiful kit fully back up and running! Any help would be massively appreciated.
Thanks so much.
Nick
