THIS looks like what you need. Never tried it myself, though!
shinobi52:Hi Guys! I would like to use my beolabs4000 for the V1 and the bs5encore. Do you have some solution? Is it possible? Thanks! Shinobi52
almando.com/
I had a very quick answer to my question.
It is designed to work with 2 B&O-sources - see the video on the homepage or on Youtube.
I am not sure if it the same with the Bosscom-version.
Why shoildn't they send to Belgium - it can only be a matter of the shipping-costs?
Greetings Millemissen
Haven't tested it, but I see no reason why it should not.
Freetings Millemissen
