Multiple source on beolabs
This post has 9 Replies | 2 Followers
shinobi52
Posts 87
shinobi52 Posted: Wed, Oct 31 2012 1:08 PM
Hi Guys!
I would like to use my beolabs4000 for the V1 and the bs5encore.
Do you have some solution? Is it possible?
Thanks!
Shinobi52
shinobi52
Posts 87
No idea?
Magnus
Norway
Posts 331
Magnus replied on Thu, Nov 1 2012 9:48 AM
THIS looks like what you need. Never tried it myself, though!
Fl_ip
Posts 160
Fl_ip replied on Thu, Nov 1 2012 12:40 PM
shinobi52:
Hi Guys!
Thanks!
Shinobi52
Connect te speakers to the bs5e. And make an connection from one of the speaker connections of the v1 to the aux of the bs5e?
jans
Belgium
Posts 394
jans replied on Thu, Nov 1 2012 4:05 PM
I just received my powerlink switch. I use it for connecting a Sonos and a V1 to the Beolabs 8000. Works perfect. Not sure however if it would work with two B&O sources.
Jan
Millemissen
Flensborg, Denmark
Posts 14,680
almando.com/
jans
Belgium
Posts 394
jans replied on Thu, Nov 1 2012 8:08 PM
Almando is similar to Bosscom, somewhat cheaper though. However, I think they only ship within Germany. I 've sent them a mail asking if they would ship to Belgium but didn't get a reply.
Jan
Millemissen
Flensborg, Denmark
Posts 14,680
I had a very quick answer to my question.
It is designed to work with 2 B&O-sources - see the video on the homepage or on Youtube.
I am not sure if it the same with the Bosscom-version.
Why shoildn't they send to Belgium - it can only be a matter of the shipping-costs?
Greetings Millemissen
shinobi52
Posts 87
Thanks for your help guys! On the video we see a V1 & à beosound5 connected :-D
But, if I connect now more beolabs on the tv to make à 5.1 setup, will it work correctly?
I would like add a pair of bl8000 for the front and put the 4000 as rear speakers. I hope that It s a good sounding solution!
Millemissen
Flensborg, Denmark
Posts 14,680
Haven't tested it, but I see no reason why it should not.
Freetings Millemissen
Page 1 of 1 (10 items) | RSS
