Hello,
I recently purchased a Beogram 4002. It's in great condition and works fine, except for one issue.
When the tonearm returns to its rest position, an audible squeaking sound can be heard.
Instead of describing the problem, I've recorded a video:
http://youtu.be/HKWLTLTtUrg
As you can see in the video, the squeak is present when the arm returns 'automatically'. In the video, I return the arm manually using the control panel. When I do this, no sound is present.
Has anyone else encountered this problem? Is this fixable?
Regards,
Hamish
Just did my recently purchased BG4002 in almost mind condition.
There are some grease problems at the back of the BG4002. Most grease is hardened and the arm that moves the needle inside has to be cleaned and given some new grease.
There is some kind of ball-bearing which seats/captured behind a piece plastic that makes this noise.
Also at the back are 2 axes that has to be overhauled. The arms that are moved by the magnet-coils doesn't move at the right speed when the needle is lowered.
The platter sits very low. Has the three transport safety screws been released ?That could indeed cause something to rub against something else inside when playing.
I noticed, the deck didn't switch to 45 RPM speed when no 12-inch record was found.This typically indicates dried out tantal capacitors on the main board. Often 1C20 and 1C21but it depends on the exact deck version and it would make sense to replace the lot (kits exists formost deck versions).
Sorry for the bad quality of the pictures Can't make pictures and pointing at things .
Martin,
You're right, the platter is low. I've just opened it up and will adjust the platter height and see if that makes a difference.
That is strange that it didn't switch speeds when no 12 inch was found. Every other time I try, it switches just fine. Weird that it didn't do it when I made the video. Regardless, I guess the capacitors should probably be replaced.
I'll report back on the platter height situation.
Thanks,
Beobuddy: Sorry for the bad quality of the pictures Can't make pictures and pointing at things .
I didn't see any pictures in your post, did you try and attach them?
Edit: now I see it, thanks.
Beobuddy: There is some kind of ball-bearing which seats/captured behind a piece plastic that makes this noise.
Beobuddy: Also at the back are 2 axes that has to be overhauled. The arms that are moved by the magnet-coils doesn't move at the right speed when the needle is lowered.
And the second one.
hammer_smyth: Martin, That is strange that it didn't switch speeds when no 12 inch was found. Every other time I try, it switches just fine. Weird that it didn't do it when I made the video. Regardless, I guess the capacitors should probably be replaced.
It pays really to become a silver or gold member.
Several service manuals with the above discribed problems can be found in these manuals.
Also some kind of improvements are mentioned for several BG4002 versions.
Update:
Problem solved.
Adjusting the platter height didn't fix the noise, but it's now at the correct height—thanks for noticing that Martin (luckily this was the first time I've used the unit, so no damage has been caused).
I ended up figuring out that applying a small amount of pressure on the wheel pictured below stopped the noise.
A drop of lubricant where the wheel meets the shaft did the trick.
Thank you all for the advice.
As you have the deck open, clean of all old grease and hardened oil, and lubricate where needed. and think about changing caps and belts, Martin can provide the correct ones
It is worth stripping the mech. as said above also re-inforce the pulley bush with some metal sheet (I wrap a thin grade round and glue) and 2-pack glue because it will eventually crack, if it hasn't done so already!!!A belt off Martin would be a good call too :)
Olly
