Beovox C75 problem
This post has 16 Replies | 1 Follower
knoydart
Posts 8
knoydart Posted: Fri, Nov 2 2012 12:11 AM
Hi!
I've just aqquired a set of beovox c75 speakers, which looks to be in good condition, no foam rot or anything, but the left hand speaker sounds muffled compared to the right, which is crisp and clear. Before I run back to the seller, is this something which could be an quick fix, like a build up of dust, or is there something damaged in there?
Sorry to be another newbie with a problem, but I figure you're the best guys to ask about b&o speakers!
DMacri
United States
Posts 881
DMacri replied on Fri, Nov 2 2012 10:01 AM
When you say muffled, it sounds to me like the tweeter is not working. So that could be a cap in the crossover, poor wire connection, or a bad tweeter. There are only a few screws holding the back plate on, so it might be worth a quick look for something amiss. I love my C75s and I hope you get this sorted soon. Good luck!
Dom
2x BeoSystem 3, BeoSystem 5000, BeoSystem 6500, 2x BeoMaster 7000, 2 pair of BeoLab Penta mk2, AV 7000, Beolab 4000, BeoSound 4000, Playmaker, BeoLab 2500, S-45, S-45.2, RL-140, CX-50, C-75, 3x CX-100, 3x MCL2 link rooms, 3x Beolab 2000, M3, P2, Earset, A8 earphones, A3, 2x 4001 relay, H3, H3 ANC, H6, 2014 Audi S5 with B&O sound, and ambio
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Fri, Nov 2 2012 10:57 AM
I agree with the above.
Most likely the tweeter itself. Note that Beovox C75 came with several different tweeters and not all
are interchangeable.
Depending on the type fitted in your speakers, I may be able to find a good used original replacement.
knoydart
Posts 8
knoydart replied on Fri, Nov 2 2012 11:38 AM
Is there a way of checking the tweeters to see if they're working properly?
Dillen
Posts 13,191
Dillen replied on Fri, Nov 2 2012 11:48 AM
Listen closely to them.
Check continuity.
Swap them.
knoydart
Posts 8
I've found that they are working, but the sound is very low, it sounds like someone's hand is over the speaker. Here are some photos of the inside if it helps!
http://farm9.staticflickr.com/8471/8147892071_74d3328057_b.jpg
http://farm9.staticflickr.com/8050/8147941578_47c0e272a7_b.jpg
http://farm9.staticflickr.com/8193/8147941648_f5ef5d6e59_b.jpg
http://farm9.staticflickr.com/8193/8147891953_4f3ba480ab_b.jpg
Søren Mexico
Mexico City
Posts 6,411
In pic one it looks like there are missing pieces to secure the coils, and someone went havoc with a soldering iron, and check the crossovers in both speakers, in the manual there is only one cap, but there may be different versions.
knoydart
Posts 8
It's exactly the same set up in the working speaker
Søren Mexico
Mexico City
Posts 6,411
knoydart:
Then lets wait to see what Martin comes up with, but if the tweeter is working good in the good speaker, try to swap them, if the "bad" tweeter is working good in the "good" speaker, the failure may be in the crossover (caps). And check that the connections in both crossovers are exactly the same.
Also if swapping, check Ohm resistance of the tweeters, should be the same + -
knoydart
Posts 8
Hi all
I've decided to send the speakers back, too much trouble for me to get fixed at the moment, I'm not giving up with B&O though, my beomaster 4000 arrived today, and I'm looking for more beovox speakers for it.
Thanks for all you help guys!
Leslie
the Netherlands City
Posts 5,423
Silver Member
Leslie replied on Fri, Nov 2 2012 9:01 PM
knoydart:
Can I be of any help?Wink
Brengen & Ophalen
knoydart
Posts 8
I'm looking for smallish speakers for it, nothing larger than the 25cm across, 4ohms preferred and under £100 if you've got any suggestions!
Leslie
Posts 5,423
Silver Member
Leslie replied on Fri, Nov 2 2012 9:35 PM
Oops! Can you name some types or else PM me..
Brengen & Ophalen
knoydart
Posts 8
hmm, something like a beovox 2200?
Leslie
Posts 5,423
Silver Member
Leslie replied on Fri, Nov 2 2012 10:18 PM
I  think I have that one, have to look in my "closet". Any other options you might be interested in? Where you from btw?
Brengen & Ophalen
knoydart
Posts 8
knoydart replied on Fri, Nov 2 2012 11:03 PM
I'm in Scotland,
I'm interested in any model really, as long as it's no wider than 25cm and will work well with the beomaster 4000
Thanks!
Leslie
Posts 5,423
Silver Member
Leslie replied on Fri, Nov 2 2012 11:10 PM
Scotland? Been there several times for my work at the Honeywell office in Newhouse. I will send you a PM what I can offer you!
Brengen & Ophalen
Page 1 of 1 (17 items) | RSS
