leogoeswild:Did you try to reset network settings?
Yep... Same problem after I upgraded to latest iOS... :-( Occasional hickups even when the iPhone is only a meter from the A1
Karel.
An issue of buggy apple software, unrelated to B&O it seems:
https://www.gottabemobile.com/ios-11-problems-5-things-you-need-to-know/
Seems to be no way so far to fix it:
https://discussions.apple.com/thread/8408210
The Bluetooth goes wrong on iOS 11? First please force restart your iOS device. Then toggle Bluetooth off and on to remove some connection errors. Also, re-add Bluetooth on settings is favorable. Or you could use third-party tools such as Tuneskit iOS System Repair. Hope my advice can help you.
See more information on How to Fix Bluetooth Issues on iOS.
