Hi all, I am hopefully going to be purchasing an older BeoVision MX4000 set soon. It is getting shipped from Italy so I am definitely a bit nervous about it but I haven't been able to find an MX set in the US. I want to purchase the rotating stand for it but I am not sure which bracket of the two shown in the picture is the correct one for the MX4000. Can anyone help?
Thanks for the reply! The stand on the left is advertised as being for the MX4000/4002. Picture of bottom shows model MB4105.
Thanks again for your help.
Yardley:Thanks again for your help.
wow! Bang from Italy :)
I'm from there and bought a blue\azure amazing MX4000 set. In USA you don't have those tvs....
anyway i'm looking for a base for it too...can you help me to find the right one? That for the MX8000 is surely not good right?
A stand from the 8000 should work with the 4000. I believe they're all compatible with all models.
I don’t think they are interchangeable. The top plates of the stands are quite different. I discussed it here: https://archivedforum2.beoworld.org/forums/p/5424/49424.aspx#49424
Further to the above - the top plates of the stands are indeed different as shown in the respective service manuals:
Each MX4000 stand (wall, floor or table-top) has a top plate that is part number: 3124122 (left photo on first post of thread)
Each MX8000 stand (wall, floor or table top) has a top plate that is part number: 3124117 (right photo on first post of thread)
They are not interchangeable - you need the correct top plate for your TV. But you can probably swap top plates between stands as long as this doesn't cause instability. (i.e putting a MX8000 top plate on a stand designed for MX4000)
