New Member... Beovision 5 Screen Replacement
This post has 4 Replies | 2 Followers
Justinonfire
Posts 1
Justinonfire Posted: Thu, Jun 21 2018 8:25 AM
Hey Guys,
My first post! I searched through a bunch of old threads and translated a bunch as well but I couldn't quite find what I was after.
I've purchased a 42" Beovision 5 second hand, and I am looking at upgrading the panel. I few things I've figured out based on my searching:
* The panel inside my Beovision 5 is a 42" Plasma from Panasonic
* The panel is connected to a B&O motherboard of sorts..
* If I replace the panel and want the speakers to work, it will have to be connected to the B&O motherboard
My questions are:
* How is the panel connected to the motherboard?
* Is there an easy way to use the tv independently of the B&O electronics while still utilising the active speaker?
Any help would be appreciated. Thanks Guys!
Justin
bigbruggsy
Posts 131
Silver Member
Hello Justin,
I'm looking at doing the same thing. Did you find away of doing this?
Regards Damian
Beolab 8000 x 2
Beolab 1
Beolab 2
Beovision 7-40
Beosound 9000
Beosound Ouverture
Beolit 12
Relator
Posts 3
Relator replied on Tue, May 28 2019 8:46 PM
it is very easy. Buy an 40" or 42" Panel LCD. Change Panel .You dont need the old motherboard, just the speaker amplifier.
anastasios11
Posts 1
Is there any way to get a breakdown of the steps?  Can I keep the built in speakers?  Will the beo4 still turn the stand?
thank you
Ravsted
Denmark
Posts 345
Ravsted replied on Wed, Jun 3 2020 8:42 PM
I know it's a while ago you asked. But i did the screen upgrade and still have full control via Beo4.
Read the step-by-step guide here:
https://archivedforum2.beoworld.org/forums/t/41909.aspx
Page 1 of 1 (5 items) | RSS
DigiCert Secured Site Seal
