Beosound 9000 mk1
This post has 5 Replies | 3 Followers
Alain Verbeke
Belgium
Posts 18
Alain Verbeke Posted: Mon, Jun 25 2018 10:07 AM
Does anybody know if an original B&O Part 8420001 CD mechanisme would fit a Besound 9000 MK1. Apparently this part was used in the MK2 version. But I would like to use it in a MK1. Would that work?
Roger
Norway
Posts 417
Roger replied on Tue, Jun 26 2018 12:09 PM
It may - you need 8005294 (8420203 from s/n 12402833) for type 2521-2530.
8420001 will fit mk2, ie type no 2561-2567 if above s/n 15143261 and below s/n 15143261. The 8420001, aka Module 96, came with a new plug connection - so it may be possible to swap plugs and make mechanical alterations to make the drive fit, but will not fit out-of-the-box.
Roger
Alain Verbeke
Belgium
Posts 18
Thanks Roger. That's helpfull.
Alain
Alain Verbeke
Belgium
Posts 18
Hi Roger,
I’m still struggling with my Beosound 9000 MK1.
The previous owner seem to have mis-matched the laser mechanism and the control PCB…
The PCB (CD-servo & decoder) that is my unit is printed B&O C6143388 and 2 with 42 (in a circle) . See pictures attached.
The wires on the plug 45, pin 5 & 6 are not connected anywhere…
I can’t find this PCB 42 on any of the service manual for the BS9000, not the MK1 nor MK2 nor MK3.
I just bought a brand new CD mechanism VAM 1205 that does not want to focus. Everything else works fine.
So, my question: can this VAM1205 work with this board? Or what board do I actually need and is it available somewhere?
thanks in advance and kind regards
Alain
PS: can not add pictures; don't know  why
Roger
Norway
Posts 417
Roger replied on Sat, Jul 21 2018 6:42 AM
Hi Alain - I´m on vacation and away from my manuals until Mid August. Hopefully someone can help out before I return!
Anyone with manuals available to assist?
Thanks,
Roger
Beobuddy
Utrecht, The Netherlands
Posts 3,972
Beobuddy replied on Sat, Jul 21 2018 8:59 AM
The servo/decoderboard next to the laserunit has to be marked with “VAM1205 only” at the connector where the wide flatcable is connected.
That’s in the original situation. A PCB board marked with 42 is a replacementboard which was used with a new mechanism years ago.
Page 1 of 1 (6 items) | RSS
