Does anybody know if an original B&O Part 8420001 CD mechanisme would fit a Besound 9000 MK1. Apparently this part was used in the MK2 version. But I would like to use it in a MK1. Would that work?
It may - you need 8005294 (8420203 from s/n 12402833) for type 2521-2530.
8420001 will fit mk2, ie type no 2561-2567 if above s/n 15143261 and below s/n 15143261. The 8420001, aka Module 96, came with a new plug connection - so it may be possible to swap plugs and make mechanical alterations to make the drive fit, but will not fit out-of-the-box.
Roger
Thanks Roger. That's helpfull.
Alain
Hi Roger,
Hi Alain - I´m on vacation and away from my manuals until Mid August. Hopefully someone can help out before I return!
Anyone with manuals available to assist?
Thanks,
The servo/decoderboard next to the laserunit has to be marked with “VAM1205 only” at the connector where the wide flatcable is connected.
That’s in the original situation. A PCB board marked with 42 is a replacementboard which was used with a new mechanism years ago.
