What volume do you listen on your BeoVision?
This post has 20 Replies | 0 Followers
Aussie Michael
Melbourne, AU
Posts 3,730
Aussie Michael Posted: Sat, Jun 30 2018 10:03 AM
I was thinking about how sometimes my settings aren't right, but it could be that im listening too low?
I generally listen to at 30 and movies at 40.
Should i be listening louder?
What volume do you listen?
oli
Southeast of France
Posts 141
oli replied on Sat, Jun 30 2018 11:23 AM
Any answer will be useless, as there are so many factors involved: source of the signal and factory level, BV model, loudspeakers connected and level settings, distance to the BV and size of the room ...
For example, on my BV11-55 in the bedroom, volume setting at 35 in movie mode through the inbuilt speaker, I have to setup the BV7-55+BL7.6 from the living room at 50 to have the same sound level. Both sources are the same: a HUMAX Satellite decoder connected by HDMI with volume setting at the maximum.
elephant
AU
Posts 8,219
elephant replied on Sat, Jun 30 2018 12:55 PM
Oli is right ... especially when you include the age of my 👂🏻 👀👂🏻
We typically have voice at 48
And big movies at up to 70
BeoNut since '75
Aussie Michael
Melbourne, AU
Posts 3,730
elephant:
i better turn it up then :-)
CB
> You are Here <
Posts 1,762
CB replied on Sat, Jun 30 2018 1:32 PM
My BV6-26, 3m away, is usually set to 30 (sometimes, I crank it up to 36-38...). And that's enough to watch (and listen to Wink) TV at any time of the day.
NB: the volume of the external DVB decoder is set at max!
Sandyb
Posts 2,186
Sandyb replied on Sat, Jun 30 2018 2:53 PM
I sit 4.5 meters from my BV12-65, and BL18 pair in the lounge.
Generally, TV at volume 50-53, louder for movies (largely to hear vocals more clearly), about 60-65.
Music varies, depends on mood, but closer to 50.
My bedroom Avant is 3.5 meters away from viewing position.
No supplementary fronts like the lounge has.
Therefore not as powerful a setup.
TV at volume 40-44.
Hope that helps.
I like it louder than most, as a general rule.
45 year old ears, for the record.
elephant
AU
Posts 8,219
elephant replied on Sun, Jul 1 2018 12:23 PM
Sandyb:
68 and 72 year old ears at this end
BeoNut since '75
Esax
Posts 323
Esax replied on Sun, Jul 1 2018 4:25 PM
7-55, bl 10 and 50.
Movie at 50-60
Music at 35-60, wife at home
Music at 60-90, home alone. No need for a massage chairStick out tongue
Beovision 7-55 MK1 red, Beolab 10 red. Beolab 50, all black. Beolab 17 broken ice. Beolab transmitter. Apple tv4 and apple express 2.
Duels
England
Posts 2,553
Duels replied on Sun, Jul 1 2018 4:39 PM
elephant:
🐘 🐘 BeoNut since '75
That’s odd - normally both ears are the same age Wink
CB
> You are Here <
Posts 1,762
CB replied on Sun, Jul 1 2018 6:43 PM
Duels:
Excellent Big Smile
Millemissen
Flensborg, Denmark
Posts 14,680
The older, the higher the volume - it stops with 90.....
.....years.
vikinger
Vestri Kirkjubyr, UK
Posts 5,422
Our BV11 is typically on 50 for watching an SD broadcast, and has to be raised to 58 to get the same volume on an HD broadcast. Switching from HD to SD can be quite a shock if you forget about prior volume adjustment.
Graham
Barry Santini
New York
Posts 543
BV9 + BL5s: regular volume 62-65.
Movies = 68-72
OldJack
Split
Posts 371
OldJack replied on Tue, Jul 3 2018 10:32 PM
Regular tv listening  at 4 met.distance, Beosystem3 with beolab 7.2 , volume 30-32
Movies,all speakers 40-42
Beogram 6500 MMC2,Beosound Ouverture,2xBeolab 8000,2xBelolab 4000,Beolab 2,Beolab 7.2,Beo4 navi, 2xBeocom2,Serene,Beosystem 3 mk3,H6 2nd gen,Earphones E8,A8,A9 keyring,Beoplay A1,Bottle opener,Beoplay A2 active(thanks Botty)Wine Set(thanks Botty),4Ktv Samsung 55'',Beolab 7.1 with 42''Panasonic plasma,,Oppo udp-203, LinTronic.
Aussie Michael
Melbourne, AU
Posts 3,730
Thank you everyone.
I now know I can turn up the volume a bit more. :-)
elephant
AU
Posts 8,219
elephant replied on Wed, Jul 4 2018 11:29 AM
Aussie Michael:
Thank you everyone.
My settings adjustment (down assuming that the L & R settings were relative to the centre has actually (as others predicted) improved on hearing and this week we seem to not need to raise the volume to hear the dialogue.
BeoNut since '75
Aussie Michael
Melbourne, AU
Posts 3,730
elephant:
Aussie Michael:
Thank you everyone.
As in your db per speaker?
elephant
AU
Posts 8,219
elephant replied on Wed, Jul 4 2018 12:34 PM
Aussie Michael:
Not sure if the BV scale is in Db.
I am referring to the settings in the 4th picture I posted a couple of days ago
BeoNut since '75
elephant
AU
Posts 8,219
elephant replied on Wed, Jul 4 2018 12:40 PM
These settings from the “background noise in movies” thread ...
https://archivedforum2.beoworld.org/cfs-filesystemfile.ashx/__key/CommunityServer.Components.UserFiles/00.00.00.22.45/IMG552028927.jpg
BeoNut since '75
Andrew
Frinton, UK
Posts 917
Andrew replied on Wed, Jul 4 2018 3:44 PM
BV8-32 - usually I have it at 60 and I am 54
There was a time when I had surround sound with my old Avant and the sound of some films was dreadful as the producers were more interested in creating loud noises to show off the surround sound - to the extent that you could barely hear dialogue - thankfully things seem much better these days.
Aussie Michael
Melbourne, AU
Posts 3,730
elephant:
https://archivedforum2.beoworld.org/cfs-filesystemfile.ashx/__key/CommunityServer.Components.UserFiles/00.00.00.22.45/IMG552028927.jpg BeoNut since '75
Ah. Yes. That’s a little bit diff on the Avant and on the Avant it’s measured in db 👍🏻
Page 1 of 1 (21 items) | RSS
DigiCert Secured Site Seal
