I was thinking about how sometimes my settings aren't right, but it could be that im listening too low?
I generally listen to at 30 and movies at 40.
Should i be listening louder?
What volume do you listen?
Any answer will be useless, as there are so many factors involved: source of the signal and factory level, BV model, loudspeakers connected and level settings, distance to the BV and size of the room ...
For example, on my BV11-55 in the bedroom, volume setting at 35 in movie mode through the inbuilt speaker, I have to setup the BV7-55+BL7.6 from the living room at 50 to have the same sound level. Both sources are the same: a HUMAX Satellite decoder connected by HDMI with volume setting at the maximum.
BeoNut since '75
elephant:Oli is right ... especially when you include the age of my 👂🏻 👀👂🏻 We typically have voice at 48 And big movies at up to 70
i better turn it up then :-)
Sandyb:45 year old ears, for the record.
Beovision 7-55 MK1 red, Beolab 10 red. Beolab 50, all black. Beolab 17 broken ice. Beolab transmitter. Apple tv4 and apple express 2.
elephant:68 and 72 year old ears at this end 🐘 🐘 BeoNut since '75
Duels:That’s odd - normally both ears are the same age
The older, the higher the volume - it stops with 90.....
.....years.
Our BV11 is typically on 50 for watching an SD broadcast, and has to be raised to 58 to get the same volume on an HD broadcast. Switching from HD to SD can be quite a shock if you forget about prior volume adjustment.
Graham
Regular tv listening at 4 met.distance, Beosystem3 with beolab 7.2 , volume 30-32
Movies,all speakers 40-42
Beogram 6500 MMC2,Beosound Ouverture,2xBeolab 8000,2xBelolab 4000,Beolab 2,Beolab 7.2,Beo4 navi, 2xBeocom2,Serene,Beosystem 3 mk3,H6 2nd gen,Earphones E8,A8,A9 keyring,Beoplay A1,Bottle opener,Beoplay A2 active(thanks Botty)Wine Set(thanks Botty),4Ktv Samsung 55'',Beolab 7.1 with 42''Panasonic plasma,,Oppo udp-203, LinTronic.
Aussie Michael:Thank you everyone. I now know I can turn up the volume a bit more. :-)
elephant: Aussie Michael: Thank you everyone. I now know I can turn up the volume a bit more. :-) My settings adjustment (down assuming that the L & R settings were relative to the centre has actually (as others predicted) improved on hearing and this week we seem to not need to raise the volume to hear the dialogue.
Thank you everyone.
As in your db per speaker?
Aussie Michael:As in your db per speaker?
BV8-32 - usually I have it at 60 and I am 54
There was a time when I had surround sound with my old Avant and the sound of some films was dreadful as the producers were more interested in creating loud noises to show off the surround sound - to the extent that you could barely hear dialogue - thankfully things seem much better these days.
elephant:These settings from the “background noise in movies” thread ... https://archivedforum2.beoworld.org/cfs-filesystemfile.ashx/__key/CommunityServer.Components.UserFiles/00.00.00.22.45/IMG552028927.jpg BeoNut since '75
