AUX not working - BeoMaster 4500/LX6000
This post has 4 Replies | 0 Followers
Vifa
Posts 24
Vifa Posted: Wed, Jul 4 2018 5:56 PM
I have a setup consisting of a BeoMaster 4500 and a LX6000.
Until recently I was able to get the sound from the LX6000 to my RL6000 speakers through the AUX connection in the BeoMaster 4500.
It suddenly stopped working - any ideas on what could be wrong?
Best Regards
Vifa
Guy
Warwickshire
Posts 2,590
Guy replied on Wed, Jul 4 2018 6:22 PM
If the leads are all connected it sounds like an 'option setting' problem.  Try this from the manual:
Vifa
Posts 24
Vifa replied on Wed, Jul 4 2018 6:28 PM
...and it was an 'option setting' problem.
I reprogrammed both devices, and suddenly it worked - thank you for the fast answer, appreciate it SmileThumbs Up
Guy
Warwickshire
Posts 2,590
Guy replied on Wed, Jul 4 2018 6:29 PM
And if that doesn't work, there's a way of changing the input options on the Beomaster:
With it in stand-by, press PROGRAMMING and the number 7 together.  The input option should be displayed (PHON OP, CD OP, or TAPE 2 OP).
While the option is displayed as above, press PHONO.  This resets the BM4500 to the factory setting which should accept a TV aux input.
Guy
Warwickshire
Posts 2,590
Guy replied on Wed, Jul 4 2018 6:31 PM
Vifa:
Excellent - I was typing th other solution whilst you posted that!  Ignore it and don't touch anything else!!! Smile
Page 1 of 1 (5 items) | RSS
DigiCert Secured Site Seal
