I have a setup consisting of a BeoMaster 4500 and a LX6000.
Until recently I was able to get the sound from the LX6000 to my RL6000 speakers through the AUX connection in the BeoMaster 4500.
It suddenly stopped working - any ideas on what could be wrong?
Best Regards
Vifa
If the leads are all connected it sounds like an 'option setting' problem. Try this from the manual:
...and it was an 'option setting' problem.
I reprogrammed both devices, and suddenly it worked - thank you for the fast answer, appreciate it
And if that doesn't work, there's a way of changing the input options on the Beomaster:
With it in stand-by, press PROGRAMMING and the number 7 together. The input option should be displayed (PHON OP, CD OP, or TAPE 2 OP).
While the option is displayed as above, press PHONO. This resets the BM4500 to the factory setting which should accept a TV aux input.
Vifa: ...and it was an 'option setting' problem. I reprogrammed both devices, and suddenly it worked - thank you for the fast answer, appreciate it
Excellent - I was typing th other solution whilst you posted that! Ignore it and don't touch anything else!!!
