On 5 dimmers, 2 are already dead, and I'm using only "old 230V bulb"!!!
The first one was changed (of course with $) by the retailer.
With the second problem the retailer asks me to send the dimmer to the manufacturer to analyse; because it's the second version.
I sent it at the begining of October.
Since I wrote a lot of email with no answer or a wide panel of lame excuses: "on holiday, we are busy, next week,..."
Finaly I asked if they are a serious compagny: the answer is: "No" !!!!!!
please don't by Unotech product!
Do they work with Beotime/ Beo4?
What are you going to use at alternate?
Beosound 8, Beotime, Beocom 4, Beo 5, Lutron Rania, MacBook 15" (Mid 2015), iPad Pro, iPhone 6S, B&O Play H3, Beolit 12, Form 2, A8 Headphones, B&O Play A1, B&O Essence
The best alternate is the BC2...
I have 3 and never had any problem!
Hey I suppose you mean LC2, BC2 (Beocenter 2) does not control lights :-)
Anyway I agree, unotech or bosscom dimmers are the same.
See my answer and issue here: http://archivedforum2.beoworld.org/forums/p/3226/31059.aspx#31059 Ideal would be if Lutron would make somthing like this compatible with the beo 4 or 6 http://europe.lutron.com/Products/productDetail.aspx?fid=solina
