Well....Dave dropped his BG4000 off on his way up north, seems it was ignoring the presence of a disc on the platter and the tone arm continued on to the centre and returned....I haven't been able to get it to reproduce this fault so as I now have a fully functional 4000 of my own, and as Sonavor suggested I will carry out some comparison tests...Daves machine on the left.
There can be seen one or two design tweeks between them...
My slightly older version....
Hooked them both up to my analogue scope, I bought a PC Scope off ebay recently and its rubbish! the drivers wont load and I suspect it was designed for 32bit systems and wont run on my 64bit laptop....disappointing
This is the trace I get from both machines measuring at the input from the Voltiac cell, Photocell in my case....not a good pic, but as can be seen not a lot of difference.
My BM6000 doesn't have any LED's either.....Collector of TR14 on both units, again very similar traces
Base of TR16 still very similar, though Daves does look a bit ragged....amplitude is the same however
Well Dave...cant replicate the issue you had, I will re assemble everything and keep trying between now and when you come to collect it....but everything is working faultlessly, I'm peased to say!
Craig
Well Dave.....moved your 4000 off my worktable and deposited it alongside my 4400, connected everything up album on the platter and switched her on only to be treated to a tone arm gliding majestically across the album completely ignoring its existence!....all I did was move it from one table to another. Lifted her back onto the work table and the symptoms where repeating over and over...aluminium plates off, visual inspection revealed nothing, no loose wires or anything hanging off. removed the position indicate/slider switch plate followed by the control panel...switch plate replaced switched on again and everything back to normal and working fine. had a look under the cover...…...
Examination of the forward/fast forward switch suggested there was not a lot of play between the switch plate and the brass contact, this has one of the plastic nipples I built up when last I had this open thinking it had worn down excessively......
With the help of one of Debbies nail file cards I reduced the amount of material on the nipple, there is now a slight hysteresis between the contact and the switch plate that I suspect will clear the problem....I will re assemble and continue the trial period
Well Dave.....been playing this all week and the only issue I could identify was a dodgy 5 pin DIN plug, seems it didn't like my 4400....but was quite happy with the BL5000, sounds odd I know but jiggling the cable when connected to the 4400 gave all kinds of stuttering and a grounding issue sort of humming....so I cut it off and fitted a new one...sounds great on all amplifiers now!
Cheers Craig! I can't wait till I can get everything set up in the new house - I'm having serious Beowithdrawal at the moment!
