Is it possible to connect a 6500 to a master control link 82 2041 and what remote will I need.
Plan to use a 6500 as an amp for a pair of penta speakers, Ipod, and non b&o tv, got most of it sorted but want to be able to control the 6500 by remote eye, that is not in the same room as the equipment.
Check the Beotech site for 6500 versus ML / MCL compatibility:
BeoNut since '75
thanks for that what connection do you use on the 6500, how much control do you have
aryliam: thanks for that what connection do you use on the 6500, how much control do you have
sadly I only have 5000s which I no longer use but keep because I have an emotional attachment to their design aesthetics !
my current BeoSound/Master/System is the BS4 which is powered on but rarely used since now days I tend to listen via music the "BeoVisions" (I am categorising the A3/iPad as my third "BV" )).
