beomaster 6500 to master control link
This post has 4 Replies | 0 Followers
aryliam
Posts 2
aryliam Posted: Tue, Nov 13 2012 4:21 PM
Is it possible to connect a 6500 to a master control link 82 2041 and what remote will I need.
Plan to use a 6500 as an amp for a pair of penta speakers, Ipod, and non b&o tv, got most of it sorted but want to be able to control the 6500 by remote eye, that is not in the same room as the equipment.
BeoHut
Posts 482
BeoHut replied on Tue, Nov 13 2012 8:34 PM
I have done this with a simple MCL transceiver (type 2046 and 2047 with IR-eye). Do not know if MCL 82 should work.
Edit: even with MCL2AV you can connect external sources in your linkroom.
First try yo find a MCL2A or a MCL2AV.
elephant
AU
Posts 8,219
elephant replied on Tue, Nov 13 2012 8:40 PM
Check the Beotech site for 6500 versus ML / MCL compatibility:
BeoNut since '75
aryliam
Posts 2
aryliam replied on Tue, Nov 13 2012 10:11 PM
thanks for that what connection do you use on the 6500, how much control do you have
elephant
AU
Posts 8,219
elephant replied on Wed, Nov 14 2012 3:34 AM
aryliam:
sadly I only have 5000s which I no longer use but keep because I have an emotional attachment to their design aesthetics !
my current BeoSound/Master/System is the BS4 which is powered on but rarely used since now days I tend to listen via music the "BeoVisions" (I am categorising the A3/iPad as my third "BV" Big Smile)).
BeoNut since '75
Page 1 of 1 (5 items) | RSS
