Hello
I'm looking for a beovox cona, and it is, of course, used.
I was wondering what i should be looking for when buying it?
I have the cx100 and I know that the membrane will break with time and I was wondering if there is a similar weakness with the Cona?
Is it easy to check though?
Okay, I will have to open it then?
Can I here if it's broken?
From what I can tell, the loudspeaker driver is quite clearly visible under the grille at the bottom (see an example). It should not be difficult to visually inspect the surrounds.
— Tuomas | Bang & Olufsen | Bang & Olufsen Create
