DAB - adding to an older system
This post has 14 Replies | 1 Follower
Mark
London
Posts 1,063
Mark Posted: Thu, Nov 15 2012 10:19 AM
Hi All
I have a Beosystem 7000 and want to add DAB or internet radio, has anyone had experience with the likes of the REVO Mondo etc ? as a simple solution.
http://www.revo.co.uk/digital-radio/revo-mondo.php
Let me know your thoughts please
Guy
Warwickshire
Posts 2,590
Guy replied on Thu, Nov 15 2012 11:59 AM
Not the system that you are suggesting but I went for the oneremote option as described in this old thread.
http://archivedarchivedforum2.beoworld.org/forums/t/40680.aspx
I have been very pleased with it.  There were photos but they have disappeared, but I should be able to post them later tonight if you want to see my set up?
(Edit)  I manged to transfer the piccies from the old forum:
And a close up showing it streaming digital music from my QNAP NAS.
Guy
Warwickshire
Posts 2,590
Guy replied on Thu, Nov 15 2012 1:11 PM
I should have added: Of course my system has DAB, normal FM, internet radio and plays music streamed over the network via wifi.  They also do cheaper versions limited to just DAB, I believe, which may suit you better.
I went for this option because I wanted the ability to control with Beo4 remote (or BeoLink 1000/5000) and this works very well.
stefan
200 miles from Struer
Posts 2,920
stefan replied on Thu, Nov 15 2012 2:11 PM
Agree with Guy. There is a DAB tuner from Oneremote that can be controled with your Beo remote via the BM7000. Works also from linkrooms.
They call it cable link option.
http://shop.oneremote.dk/catalog/product_info.php?cPath=5_14&products_id=3451
There you will also find a manual in english...
Hope this helps
Stefan
Mark
London
Posts 1,063
Mark replied on Thu, Nov 15 2012 3:38 PM
Steffen
Denmark
Posts 1,408
Steffen replied on Thu, Nov 15 2012 10:30 PM
Guy:
I would like to know a little bit more about this DAB/wifi receiver.
I have one that looks excactly like yours from IRC (also with DAB/FM/internet/wifi) - but mine can not be controlled with B&O remotes - and it only has phono plugs.
I have it connected to a BC 9500 like you Cool - but I have to use that crappy remote from IRC to control it Super Angry
Did they make a special version for B&O - and is it still available?
Guy
Warwickshire
Posts 2,590
Guy replied on Fri, Nov 16 2012 9:03 AM
I think that 'oneremote' take the IRC receiver and modify it to work with the Beo4, either directly via the (modified) IR receiver, or through the cable that connects it to the Beocenter.  The output from the modified receiver is a 7-pin DIN (datalink).  I have never used the IRC remote that came with my receiver - there is no need as everything can be controlled by the Beo4, even from link rooms as stated by Stefan.
Perhaps you could contact 'OneRemote' and ask them to modify the one that you already own?
TWG
Posts 1,672
TWG replied on Fri, Jul 18 2014 12:40 PM
Guy:
An old thread, I know, but  could somebody tell me the name and manufacturer of this nice thingy in the picture above? :-)
Mark
London
Posts 1,063
Mark replied on Fri, Jul 18 2014 1:18 PM
the details on above DAB receiver can be found here design.aspx?articleid=2299&zoneid=5
TWG
Posts 1,672
TWG replied on Fri, Jul 18 2014 1:53 PM
Thank you  :-)
Millemissen
Flensborg, Denmark
Posts 14,680
I once had one of those - sure it works.
It became obsolete, after I bought my first AirPort Express (which was succeeded by a Playmaker), and I  used the iPad to play Netradio in better quality - a system much easier to manage.
I am sure they would still modify that, if you want to spend the money on it - even if they today offer a different version.
Guy
Warwickshire
Posts 2,590
Guy replied on Fri, Jul 18 2014 6:53 PM
TWG:
They were obviously my pictures above, although I have now moved house (and from Denmark to Germany!).  They don't do my receiver any more but this is it's replacement and they also have a DAB version:
http://shop.oneremote.dk/catalog/index.php?cPath=13_21
I prefer the oneremote systems to using my Playmaker, mainly because of the ease of controlling with Beo4, including from link rooms, and also the ability to turn it on in the mornings automatically with the timer that is built in to my BC9500.
Millemissen
Flensborg, Denmark
Posts 14,680
Guy:
That is a point - I must admit.
hotknife
Germany
Posts 840
hotknife replied on Tue, Dec 29 2015 8:50 AM
Hi guys,
o.k. the input of the one remote is a little old. Millemissen suggested the one remote, because I´d like to upgrade my Beosound 4 with DAB+ and/or DAB+ with internet radio.
Does anybody know it the RDS text will be shown on the one remote unit or the Beosound unit if the one remote is fixed to the Beosound via AUX-input?
Thank you for your answers, take care
LOEWE bild 5.55 OLED + AppleTV; BS4; BL9; BL8000 MKII all black
Millemissen
Flensborg, Denmark
Posts 14,680
@warmmesser
BeoSound = sound only and the 'OneRemote unit shows the text.
By the way - you should be able to get a DAB-kit for the BS4, but they are rare.
Page 1 of 1 (15 items) | RSS
