I've searched as best I can but can't find the answer to this!
I've been lucky to have purchased a Beovision 7-40 TV which I was informed was a MK5. However, the info I've gleaned on here and the internet seems to indicate that the MK5 came out in 2010 and my TV has the legend 'B&O MMIV' (I'm guessing this is 2004). The label on TV reverse says [type - 9644] and [Item - 1807487]... can anyone give guidance?
Many thanks.
Thanks Chris. Is there a definitive way to tell which 'MK' it is?
To tell the exact age you need the serial number it is 8 digits starting with 21* or 22
type 9644 should be MK5😊
Søren
https://archivedforum2.beoworld.org/forums/p/3853/34502.aspx#34502
Major difference in BV 7-40 MK4, MK5 & MK6
Ralf
