Which 'MK' do I have?
This post has 5 Replies | 0 Followers
johnnythedep
Posts 2
johnnythedep Posted: Mon, Sep 24 2018 9:52 AM
I've searched as best I can but can't find the answer to this!
I've been lucky to have purchased a Beovision 7-40 TV which I was informed was a MK5.  However, the info I've gleaned on here and the internet seems to indicate that the MK5 came out in 2010 and my TV has the legend 'B&O MMIV' (I'm guessing this is 2004).  The label on TV reverse says [type - 9644] and [Item - 1807487]... can anyone give guidance?
Many thanks.
Chris Townsend
Qatar
Posts 3,531
I’m pretty sure the 2004 refers to when the 7-40 was launched, not its Mk 5 variant.
johnnythedep
Posts 2
Thanks Chris.  Is there a definitive way to tell which 'MK' it is?
Chris Townsend
Qatar
Posts 3,531
Look for the type number on the white piece of paper on rear. Should be four numbers then google it.
Soren
Denmark
Posts 115
Soren replied on Mon, Sep 24 2018 12:17 PM
To tell the exact age you need the serial number it is 8 digits starting with 21* or 22
type 9644 should be MK5😊
Søren
kallasr
Germany
Posts 2,562
kallasr replied on Mon, Sep 24 2018 2:35 PM
https://archivedforum2.beoworld.org/forums/p/3853/34502.aspx#34502
Major difference in BV 7-40 MK4, MK5 & MK6
Ralf
Page 1 of 1 (6 items) | RSS
