Help with SP12 cartridge - SOLVED
This post has 21 Replies | 1 Follower
Haventgotaclue
Posts 20
Haventgotaclue Posted: Thu, Oct 4 2018 1:49 PM
hi all
im new to this site and Beogram turntables hence the user name! I need some help from you experts 😊I bought a beogram B&O 1202 TT and sourced a cartridge and stylus SP12 from a 1203 but the cartridge does not sit flush with the 1202 tone arm? Leaves a gap of roughly 1cm where the black ends are, the end of both tone arms is slightly different with the 1202 arm having slightly protruding pin holes which appears to be the problem? Help! Dave
chartz
Burgundy, France
Posts 4,171
chartz replied on Thu, Oct 4 2018 2:56 PM
Double post Angry
Jacques
chartz
Burgundy, France
Posts 4,171
Hi, and welcome!
Glad to help but a picture would help!
It appears the 1202 arm must be the problem. Nothing must protrude and the cartridges are interchangeable.
Push the cartridge connector back into the tube. Is the screw underneath still present?
You will probably have to adjust the angular position of the SP12 so that it rides perfectly parallel to the surface of a record.
Jacques
Haventgotaclue
Posts 20
Hi Jacques
having trouble uploading a photo at present but the stylus is actually a SP14 my bad 😖, the end of the tone arm has the four pin holes but they protrude slightly out so leaving a gap once I fit the cartridge, on the 1203 TT the pin holes are flush. There is a screw under the tone arm
chartz
Burgundy, France
Posts 4,171
chartz replied on Thu, Oct 4 2018 3:29 PM
So just push the connector in, then tighten the screw and check that it’s true. All these carts share a body.
Does it look like this?
Jacques
Haventgotaclue
Posts 20
It’s hard to discribe the pin connector the cartridge sits on has raised pin holes not flush pin holes?
Haventgotaclue
Posts 20
Just seen the photo no isn’t out like that one the actual connector is sitting in but like I said above the pin holes are raised
chartz
Burgundy, France
Posts 4,171
chartz replied on Thu, Oct 4 2018 3:45 PM
Download the Beoworld App which allows pictures directly taken from your mobile and I’ll advise.
Jacques
Haventgotaclue
Posts 20
Haventgotaclue
Posts 20
Hi as you can see from this and previous photos doesn’t sit flush because of the raised pin holes and thank you for pointing me towards the app Smile makes life easier!
chartz
Burgundy, France
Posts 4,171
chartz replied on Thu, Oct 4 2018 4:04 PM
Okay. The tonearm looks normal. May we see the cart’s pins?
Remove the small insulators/spacers.
Jacques
Haventgotaclue
Posts 20
Here’s a pic of the cart
Haventgotaclue
Posts 20
What are the insulators spacers?? Thank you
chartz
Burgundy, France
Posts 4,171
chartz replied on Thu, Oct 4 2018 4:24 PM
Mmm... it looks normal as well.
Remove the spacers stuck at the arm’s connector and you should be fine! Stick out tongue
Jacques
Haventgotaclue
Posts 20
That’s what I thought too, could it be a different tone arm has been put on because like I said the pin holes have raised pin heads on them compared to the flush ones of the 1203 ( 2nd photo) which the cart fits perfect?! See the difference?
chartz
Burgundy, France
Posts 4,171
chartz replied on Thu, Oct 4 2018 4:31 PM
Take the spacers that are stuck out!
The spacers should be with the cartridge, not stuck on the arm’s connector.
Jacques
Haventgotaclue
Posts 20
Ok thank you what is the best way to remove as it seems well stuck in the arm at the moment!
chartz
Burgundy, France
Posts 4,171
chartz replied on Thu, Oct 4 2018 4:42 PM
Use the missus’ tweezers! Do insist a bit, there is no risk. Hold the tonearm while doing so.
Jacques
Haventgotaclue
Posts 20
Ok will give it a bash and get back to you Big SmileBig Smile
chartz
Burgundy, France
Posts 4,171
chartz replied on Thu, Oct 4 2018 4:45 PM
Haventgotaclue:
Wink
And don’t forget to edit your thread title as [solved] when you’re done.
Jacques
Haventgotaclue
Posts 20
Success!! Thank you very much a much better fit Wink
chartz
Burgundy, France
Posts 4,171
chartz replied on Thu, Oct 4 2018 4:47 PM
Good! Well done then!
Jacques
Page 1 of 1 (22 items) | RSS
