Jacques
Hi Jacques
having trouble uploading a photo at present but the stylus is actually a SP14 my bad 😖, the end of the tone arm has the four pin holes but they protrude slightly out so leaving a gap once I fit the cartridge, on the 1203 TT the pin holes are flush. There is a screw under the tone arm
It’s hard to discribe the pin connector the cartridge sits on has raised pin holes not flush pin holes?
Just seen the photo no isn’t out like that one the actual connector is sitting in but like I said above the pin holes are raised
Use the missus’ tweezers! Do insist a bit, there is no risk. Hold the tonearm while doing so.
Haventgotaclue:Ok will give it a bash and get back to you
Good! Well done then!
