My Beolab 5000
This post has 240 Replies | 0 Followers
Craig
Yarm, United Kingdom
Posts 2,040
Silver Member
Craig Posted: Thu, Oct 4 2018 8:37 PM
So beguiled by Peters Beolab that when I spotted this on ebay I had to enter into a two day long haggle with the vendor.....he was a hard man but we reached an accord and the deal was struck (not as good a deal as I was hoping, but a fair price judging by the quality of Peters machine).
Craig
Posts 2,040
Silver Member
Vendor advised his father acquired this in 1970 and was the sole owner, naturally he had no speakers or means to test but felt there was every chance it was fully functional, the red power lamp glows when powered up, therefore was sold as spares or repair.....I cant resist a challenge. The front face text has all but worn away but cosmetically is doesn't look like it has been in the wars, screw heads look untouched.
Craig
Posts 2,040
Silver Member
Dragooned the variac back into service and slowly put some power to her....no runaway current or nasty smells (and the lamp started to glow) so pretty good so far.
Craig
Posts 2,040
Silver Member
Plugged in my Ipad and a couple of speakers, PHONO set to HIGH, and had a listen......mixed result. lots of snap, crackle and silences as I played with the volume slider and various front switches....but overall I think its all there, Powered down and took the top off.
Craig
Posts 2,040
Silver Member
Massive amounts of dust...….
Craig
Posts 2,040
Silver Member
Little wonder the switches and sliders are a little twitchy......
Craig
Posts 2,040
Silver Member
A good cleaning is in order before any work can be done
Craig
Posts 2,040
Silver Member
Some of the transistor cans have started to oxidise quite visibly..I suspect they will have to go
chartz
Burgundy, France
Posts 4,171
chartz replied on Thu, Oct 4 2018 9:18 PM
Welcome to the owner’s club.
That is some amp, you’ll hear Stick out tongue
Jacques
Peter
Earsdon
Posts 11,991
Peter replied on Thu, Oct 4 2018 9:42 PM
I think Frede could possibly help with the front panel. He has arranged to get them etched rather than the original transfer type. I don't know if your ever saw his black Beolab 5000 system!
Peter
Søren Mexico
Mexico City
Posts 6,411
Here my new front panel from Frede, the sliders are the old ones, but Frede has with sliders too, recommended. There is a difference left to right in the pic because of light from a right side window,
Craig
Posts 2,040
Silver Member
Craig replied on Fri, Oct 5 2018 9:35 AM
I have had some correspondence with Frede regarding refurbisnment of the front panels and it looks like he provides an excellent service, quite costly however...and should I run into difficulties that render the project terminal I would feel agrieved, so I will progress the restoration first and providing all goes well sort out the front panel cosmetics. I may even be able to pick up a complete unit with a decent front in the meantime for a similar cost.
chartz
Burgundy, France
Posts 4,171
chartz replied on Fri, Oct 5 2018 2:18 PM
I still have to do mine, which is 100 % original (and pretty mint). The only thing I ever replaced in there was a bulb! So no crackles or hiss, no funny smells or noises. Just music!
What I find impressive is the fact that in spite of this original condition, it works really well. It is easily one of my best amplifiers.
The only thing I dislike is the thump when I power it on.
One of these days I’ll be bold and open it again and replace all those old caps, as you did Søren.
I don’t have a distorsion meter though, so although all voltages are reasonably close to the ideal values, I would perhaps be surprised to see high values there.
A few years ago, Tim had his measured and it still behaved impeccably.
Jacques
Craig
Posts 2,040
Silver Member
Heres a curious thing, when I lifted the circuit board up (and this had never been lifted before, i'm quite sure) the corner fell off along with the retaining screw......as can be seen from this picture, left hand side corner, the same board on Peters machine has also suffered the same damage, it has bee epoxy glued back in place (Frede I would think) so I will repair it in the same way....theres a theme here....anyone else had this?
Søren Mexico
Mexico City
Posts 6,411
Here the cost and time table for my first one. Jacques both my units has the thump. Turn off speakers, volume in "0" turn on power, leave for 2 min, turn on speakers and volume, no thump
BL/BM 5000 calculation
Date Work done Hours Spare parts Price USD
8/01/15 Pre check 2.50 Buying price S and H 450.00 USD
8/01/15 Photos 1.00
8/02/15 Dismantling 3.00
8/02/15 Photos 2.00
8/03/15 Desoldering components 4.00
8/04/15 Desoldering TR Check 4.00
8/05/15 TR Check, Dism. BM 3.00
8/05/15 Photos 2.00
8/06/15 Engraver visit 1.00
8/07/15 Transformer 1.50
8/08/15 Transformer, Cleaning, caps 3.00 Paint and screws 17.50 USD
8/09/15 Wood BL 1.00
8/24/15 Wood BM 1.50 Caps, lamps Martin 60.00 USD
8/24/15 Photos 3.00 Frede Fronts 489.00 USD
9/28/15 New caps and clean 2.50
9/29/15 New caps and clean 3.00
10/05/15 Checking transistors 1.00 Mouser caps and Trs 40.00 USD
10/08/15 New caps BM 2.50
10/12/15 Change transistors (Bl drop) 3.00
10/13/15 Change transistors (Bl drop) 1.50
10/14/15 Asmb. Trs to cooling 3.00
10/15/15 Asmb. Transf. Side 3.00
10/16/15 Sold. PCB 03, + caps, Sw.asmb.
Mount. PCB 01, sold. To Sw.asmb 4.00
10/27/15 Chassis front, V and Bal sliders 3.00
10/28/15 Bass and Treble sliders, PCB 2 4.00
10/28/15 Photos November 3.00
10/31/15 Sold. PCB 2 and placed wirebundles 2.00
11/01/15 Adjust and failure finding 3.00
11/02/15 Failure finding 1.00
11/04/15 Test and adjust, Front on 3.00
11/10/15 Failure finding 2.00
11/17/15 Failure finding 3.00
11/18/15 Failure finding 4.00
11/26/15 Oscilloscope ordered
12/09/15 Failure finding w/Osc. 2.00
12/11/15 Polarity BC 154, Test w/tuner 3.00
12/26/15 Phono input, swithch 2.00
12/27/15 End assembly 2.00
93.00
1,056.50 USD
Craig
Posts 2,040
Silver Member
That's an impressive list Soren......and five months of your life, what better way to spend it! I was fortunate enough to be on a worksite today and charmed the Instrument technicians into letting me use a compressed air line in there workshop, looks a lot better with most of the compacted dead skin and mummified flies and spiders blown away...
Craig
Posts 2,040
Silver Member
Still a long way to go however...…..
Craig
Posts 2,040
Silver Member
Lifted the transformer out and using a wire wheel on my Dremel removed all the rust, will need to paint it before it goes back, thought perhaps silver Hamerite ?
Søren Mexico
Mexico City
Posts 6,411
I cleaned off more rust on mine, down to bare steel, grounded with an anti oxid grounder and then sprayed with light gray hammered (spray can)
Craig
Posts 2,040
Silver Member
Craig replied on Sat, Oct 6 2018 7:27 AM
soren
Most of the pictures on your thread have disappeared.....(Beolab 5000), is it possible to get them back up?......I will remove the transformer completely and get down to bare metal and do as you suggest  with primer first 😉
Søren Mexico
Mexico City
Posts 6,411
will try o get them back up
Craig
Posts 2,040
Silver Member
There....will be a lot easier to deal with now its removed...
chartz
Burgundy, France
Posts 4,171
chartz replied on Sat, Oct 6 2018 8:11 AM
A work of dedication.
I can never be bothered when I see rust. I just frown and move on to something else. Had my Beothingies been in that kind of condition, I would never have spent the hours.
You guys are brave, and I look up to you and salute you Yes - thumbs up
Jacques
Craig
Posts 2,040
Silver Member
Ok.....down to bare metal, almost tempted to put it back like this ;¬)
Craig
Posts 2,040
Silver Member
And a coat of primer....
Craig
Posts 2,040
Silver Member
Whilst waiting for the primer to dry I have taken out the power supply smoothing caps, big old boys...new ones will be much smaller. Bit more room to work in now, the bottom panel will have to come out for a good clean too
Craig
Posts 2,040
Silver Member
These fellows turned out to be well out of spec....
chartz
Burgundy, France
Posts 4,171
chartz replied on Sat, Oct 6 2018 2:26 PM
Craig:
They always are - and yet keep going! I replaced those on almost all my B&O (or Quad, Revox...) vintage gear and they are always bad-ish but keep doing what they were intended for.
Jacques
Craig
Posts 2,040
Silver Member
Finished article.....looks better than when it was new ;¬)
chartz
Burgundy, France
Posts 4,171
chartz replied on Sat, Oct 6 2018 7:23 PM
When new it was just tinned. It could be done with tin paste I guess.
Yours looks like Søren’s !
Jacques
Craig
Posts 2,040
Silver Member
Starting to look a little scary seeing everything scattered across my work table...good job I have Peters machine to hand in case I get lost!
Søren Mexico
Mexico City
Posts 6,411
Craig:
Nearly better than mine Big Smile
Søren Mexico
Mexico City
Posts 6,411
Craig:
Working on the pics in my thread, will finish tomorrow, 3 hours today. Checking where missing, finding them in my PC, uploading to my files one by one, then in the thread posting in edit, which means click film strip, click Soren Mexico files, click this again, click BL 5000, click subfile, find pic, double click, check if right, and that for every friggin pic, its really a PIB
Craig
Posts 2,040
Silver Member
Craig replied on Sat, Oct 6 2018 8:49 PM
That's great Soren...appreciate you taking the time to do so, I don't suppose you kept a record of the transistor equivalents you purchased did you? Embarrassed
chartz
Burgundy, France
Posts 4,171
chartz replied on Sat, Oct 6 2018 9:52 PM
At the time I didn’t quite get why anyone would replace perfectly good semiconductors.
No funny noises, no hiss? Why change?
I’ve read the same thing about QUAD when I restored my 33/303/FM3. I left the transistors alone and it all sounds perfectly good and completely silent.
Jacques
Søren Mexico
Mexico City
Posts 6,411
Here some remarks from Martin, I mostly used BC546-550B and BC546-560B and when no match there I vent here and got the closest i could get, used Mouser a lot, also for the caps, in my second one I used radial caps where I could and only axial where needed mostly Nichicon and panasonic.
Martin:
BC550A (low HFe range)
BC550B (medium HFe range)
BC550C (high HFe range)
All other parameters are basically the same.
Regarding noise-levels:
BC107, BC108, BC109 are in reverse order of noise-level. (They will also have the last A,B or C attached for HFe range identification).
Same goes for BC546, BC547, BC548, BC549, BC550 - largely speaking.
SE8002 can be replaced by BC141
BC109 can be replaced by BC550
When replacing the "vintage" transistor types, I like to use HFe range B transistors.
Using C's instead will not necessarily improve anything.
Here a list for caps, but check the ones in yours first, there are differences one unit to the other
Radial Capacitors pcs
10 µF 64V 10
100 µF 6,4V 6
200 µF 10V 2
25 µF 25V 14
2500 µF 100V 1
3000 µF 50V 2
4 µF 64V 2
50 µF 40V 2
80 µF 25V 8
250 µF 16V
1
Axial Capacitors
Pcs
100µF 6,4V 4
100µF 64V 1
10µF 64V 3
160µF 25V 4
25µF 25V 5
400µF 40V 2
4µF 64V 2
50µF 40V 2
80µF 25V 3
Søren Mexico
Mexico City
Posts 6,411
Here one order from Mouser
Craig
Posts 2,040
Silver Member
Soren
Thank you for the info...I realise this has probably increased your time spent on your Beolab thread by another man week ;¬)
I have cleaned and wire brushed all the debri from the base plate.
Craig
Posts 2,040
Silver Member
Coat of primer.....
Craig
Posts 2,040
Silver Member
And finally a coat of Matt black to finish, spent a bit of time on miscellaneous brackets and clamps.
Page 1 of 7 (241 items) 1 2 3 4 5 Next > ... Last » | RSS
