Recloth BeoVision 10 46 cover
This post has 3 Replies | 0 Followers
kallasr
Germany
Posts 2,562
kallasr Posted: Fri, Oct 12 2018 2:05 PM
Has anyone done this?
I would like to change to white speaker frets but
a) not easy to find for a reasnable price
b) have read that there have been bad experiences with dust/dirt that could be seen after a while
So, looking for your advice...
Thanks in advance
Ralf
kallasr
Germany
Posts 2,562
kallasr replied on Mon, Oct 15 2018 7:56 AM
Was just approved after moderation. Date was the original one so writing this to push this thread....
lawrencejmcook
Posts 742
Hi, I have white frets on my BV9 and BL5s - they simply need regular, gentle cleaning with a vacuum cleaner on low suction with a brush attachment. Just remember, the white just makes the dirt more visible, so if you have black frets, they are likely just as dirty, but you don’t notice it! 😊
Another point is, if you do decide to re-cover the speakers, choose the fabric carefully. Through the white fret on my BV9 I can see the holes for the speakers, whereas on the BL5s they are less obvious. You need to balance acoustic and visual transparency.
Lawrence
Mikipidia
Posts 2,169
Mikipidia replied on Mon, Oct 15 2018 7:59 PM
A kind gentleman can do it and you can reach him at: pingvin@live.nl
Had my extra eclipse cover done and sent it to Erik in sweden as b&o in white is his thing Stick out tongue
Mikipedi4 on Twitch: https://www.twitch.tv/mikipedi4
Mikipedia on Intagram: https://www.instagram.com/mikipedi4/
Old: Beosound 9000 mk3, Beolab 3's, Beovision Eclipse, Beolab 1's, Beolab 2, Beovision 10-46, Overture 2300, beolab 8000's, Beolab 4000's, Beovision avant 32" etc. etc.
Page 1 of 1 (4 items) | RSS
