Has anyone done this?
I would like to change to white speaker frets but
a) not easy to find for a reasnable price
b) have read that there have been bad experiences with dust/dirt that could be seen after a while
So, looking for your advice...
Thanks in advance
Ralf
Hi, I have white frets on my BV9 and BL5s - they simply need regular, gentle cleaning with a vacuum cleaner on low suction with a brush attachment. Just remember, the white just makes the dirt more visible, so if you have black frets, they are likely just as dirty, but you don’t notice it! 😊
Another point is, if you do decide to re-cover the speakers, choose the fabric carefully. Through the white fret on my BV9 I can see the holes for the speakers, whereas on the BL5s they are less obvious. You need to balance acoustic and visual transparency.
Lawrence
Mikipedi4 on Twitch: https://www.twitch.tv/mikipedi4
Mikipedia on Intagram: https://www.instagram.com/mikipedi4/
Old: Beosound 9000 mk3, Beolab 3's, Beovision Eclipse, Beolab 1's, Beolab 2, Beovision 10-46, Overture 2300, beolab 8000's, Beolab 4000's, Beovision avant 32" etc. etc.
