My tv’s (V1 and Avant/2014) behaves similar, when there is no quick timer at that moment.
I can wake them up by tapping the product in the product view of the app.
After that they appear online in BeoTool.
How do quick timers work on a BV14?
I could not find anything in the user guide.
Don't think it's a quick timers thing because the Avant is always available on the tool. Gen 1 Avant like yours... or your V1.
Naturally if i wake it , it will appear
But it's affecting the behaviour of waking up from the BeoApp. It says waking up, but then is blank.
Hmmmm :-)
Millemissen:My tv’s (V1 and Avant/2014) behaves similar, when there is no quick timer at that moment. I can wake them up by tapping the product in the product view of the app. After that they appear online in BeoTool. How do quick timers work on a BV14? I could not find anything in the user guide. MM There is a tv - and there is a BV.
Did you solve this issue? I’ve got the same issue with my BeoPlay V1 - can’t find what’s causing it!
Did the recent BV14 software update make any improvements?
On Thursday 6 Dec my BV14 went from 7.0.209 to 8.1.013. It was our first upgrade since installing it 3 months ago, and while exciting to watch the upgrade, I cant tell any differences other than volume control is more laggy on the Beoremote Ones. Curious the release date was: 2018-11-02 and I very regularly check for updates.
I was hoping for an Android update, but as far as I can tell I am still on Nougat.
I still have always had red on software update on the BeoTool app; and it is still red after the update. I have assumed that function on BeoTool cant work with Android; but that is just a guess.
I am hoping that the BV14 can ride the Horizon's coat tails for future upgrades? I assume there are not that many differences between the two/
My BV14 also went to 8.1.013 last night after watching it. I shut the TV down at 10 and it started the update and then the android update. And that was the first update apart from the one that I did when i purchased the TV and it was set up (by me).
It has no release notes, which is annoying.
The android version is 5.1.1 according to the TV.
I get a green now on all services on the BeoTool, so hopefully it would be fixed. But prior to this i woke the 14 up via the BeoApp, so maybe that helped make all services green. Even though it says all services are green ist says that the BeoVision 14 is offline.
So now when i look in the BeoApp and click on the BV14 and under where it says Name, Software and About, I click on the name and there is a pop up that says "You need to use Apple Home app to change the product name" - why? That's odd.
I did change the name of the TV when i set it up so that it is easier to see on the network.
My BV14 was also updated... but haven't seen anything new/changes. Ok.. I have to admit... I looked for 30sec in de settings.
Anyone have access to a changelog?
Karel.
Beovision 11-55, BeoPlay V1 40, Beosound 9000, Beolab 8000's and 3 Beocom 5's...
Gennaro:Just curios, do they ever plan on updating the android version on these ng’s??? So sad.... B&O is not the same anymore
Don't count in it... I have a feeling that the hardware in the BV14/Avant doesn't support the newer Android versions.
And if the hardware would support such an update I doubt if B&O would dare to make an update to a newer Android version given the various software issues it had (or still has...).
