Uuuh - that’s a tricky one.
Don’t know if that will help, but it is the answer to one of your questions:
’If you need to reset your television to default settings, then bring up the REGIONAL SETTINGS menu and select another country.
You will be asked to confirm the reset. All settings will be deleted and you must go through first-time setup, follow the on- screen instructions’
as written in the user guide.
I don’t know if there is any other way to do this?
Beware - you will have to make all settings again, which can be quite a job.
So be sure to make notes/take pics of your settings before you go along.
P.S. I’d remove all connections before getting on with it.
P.P.S. This is something that I would only do, if the is no other ‘cure’ to the problem/s.
Millemissen:Uuuh - that’s a tricky one. Don’t know if that will help, but it is the answer to one of your questions: ’If you need to reset your television to default settings, then bring up the REGIONAL SETTINGS menu and select another country. You will be asked to confirm the reset. All settings will be deleted and you must go through first-time setup, follow the on- screen instructions’ as written in the user guide. I don’t know if there is any other way to do this? Beware - you will have to make all settings again, which can be quite a job. So be sure to make notes/take pics of your settings before you go along. P.S. I’d remove all connections before getting on with it. P.P.S. This is something that I would only do, if the is no other ‘cure’ to the problem/s. MM There is a tv - and there is a BV.
Ok, the BeoSystem 4 version.
The Beovision Avant is based but not exactly the same as BSys4. This reset process is straight from the Beosystem 4. You may be lucky.
Otherwise, In your version some changes relate to its 4K capability. Its likely you need a call to service to reset this properly including all its capable resolutions.
I believe also that there is a video test mode that can be invoked or a manual test procedure to help. Both maybe of assistance.
Good luck, Beoaus.
Thanks, i have called them and now await their response
You mention "this reset process is straight from the Beosystem 4"... were you going to write what that process was (by your sentence) or was it more for my info?
Thanks again
Last night it fixed itself and i was watching Foxtel for a few hours and this morning again it stuffed up
I tried again this arvo with Hot Seat at 5 and at 5:40 it started to go.
KMA
B&O product history since 1991: Ridiculously long to list in a signature.
ouch :(]
It is possible that re seating a connector or two may help. These connectors are inside the panel which on an Avant makes it harder.
This is a link I have just found that may or may not be relevant.
Good luck.
Aussie Michael:The issue is diagnosed as “solarisation”
https://en.wikipedia.org/wiki/Posterization
https://en.wikipedia.org/wiki/Solarisation
-- Mr. FussBudget.
So service came out today to fix the Avant.
Prior to them coming out my 4K worked on the Xbox and the 1080 content did not work.
The video engine was changed and then 4K didn't work on half of the screen.
They mentioned that it is my Xbox but i didn't think it was. After they left, i tested with an Apple TV 4K and it replicated the same problem.
So now i can watch 1080 and I can't watch 4K.
This is getting bloody annoying as it is only 4 years old and therefore at my expense - im going to do some research in to our Australian Consumer Law about implied / statutory warranty shortly.
I'll post some pictures.
Anyone got any suggestions of what it might be?
Thanks Mike, i know you thought it was the connections, but the service guys said it wasn't the connections.
Aussie Michael:Thanks fo your suggestion. All cables are compliant and there was no issue prior to the video engine change with 4K I have tried an Xbox one and also Apple TV 4K and they have the same issue. If I change the resolution down to 1080 on both there is no issue. But what’s the point of having a 4K tv if you can’t use the 4K. So now the problems have reversed Something you might like is that on the Xbox you can change the 4K to 8 bit. Cheers
They were both tested on HDMI 1, so thank you for your input. 👍🏼
Hi Michael, my name is Francesco and i'm new to the forum.
I'm having your same issue with my Avant 55 MK1. Just a week ago, my Avant start to have strange images like yours with any sources.
B&O service changed the video engine board and everything came back to normality except one think.
My Avant now has a split screen issue when connected to 4k resolution source, as show in your latest image.
Could you please tell me how your service repaired the problem?!?
Please help, thank you.
Hi Francesco
Welcome to the forum, it's great to hear from you.
Sorry to read of your issue.
Yes, the service department did fix my TV. They were good to deal with and followed up as promised.
If yours is 4K, then i think that perhaps they need to come back and ensure they have seated all the cables properly. I think your issue looks like they haven't tested or connected the cables properly.
If you ring them, they may confirm this with B&O and come back to your house.
Is it just 4K sources or all sources?
The reason i ask is that is , if it is all it looks like it has 3D enabled (somehow) which you can switch off. But if it's just 4K it may be a cable issue.
