Bought a 4002 that was modded to accept phono cables...what shall i use?
This post has 4 Replies | 2 Followers
starkiller
Posts 44
starkiller Posted: Thu, Nov 15 2018 10:48 PM
Bought a 4002 that the seller modded with RCA jacks to accept choice of cables.  Done as per the Belover site.  Would like to know if anyone has a preferred or recommended brand of cables to use or just get a decent set of any brand...
thanks!
chartz
Burgundy, France
Posts 4,171
chartz replied on Fri, Nov 16 2018 6:09 AM
A can of worms this. All the world’s crooks in there.
The day anyone will prove that there is a difference will win my admiration.
Since B&O use moving iron cartridges, capacitance is not critical. Just use any cable or, better, retro-fit an original DIN-terminated one.
Perhaps not the kind of answer you were expecting, but there you are! Wink
Jacques
Steve at Sounds Heavenly
The cable workshop, Leics, UK
Posts 2,165
chartz:
Big Smile
Hi chartz,
I agree, cable capacitance isn't an issue here.  However, due to the low output voltage from the MMC cartridge, loop resistance of the cable and connectors can make a difference to the output level, also poorly shielded cables can be very susceptible to induced electrical noise.
Hence, no "snake oil" super cables are needed, just common-sense, good quality cable with decent shielding of the signal conductors and low resistance to minimise signal loss.  As always, please keep the cable length as short as reasonably possible (ideally a metre maximum) when connecting an early Beogram to a pre-amp or main system.
Kind regards, Steve.
Steve.
www.soundsheavenly.com
starkiller
Posts 44
Thanks to everyone who has responded...will just get a good quality cable set then...:)
starkiller
Posts 44
Page 1 of 1 (5 items) | RSS
