Hi there,
So I bought my Beolab 17's about 4 years ago and with the idea of expanding to add a 19 and then hopefully 18's.
Well finally I walked in an purchase the 18's but need to pick them up.
Now my question is, which solution would you guys recommend.
At the moment my equipment list is:
Beolab Transmitter 1
Beosound Core
Beolab 17's
Beolab 19.
LG OLED B6 TV
Xbox One X
Right now I have, PL from Beosound core to Transmitter 1 and Toslink from TV to Transmitter 1. Xbox to TV via HDMI
However, now I need to add 2 more channels of sound and I need some help choosing between the
Axiim Q UHD - https://axiim.com/products/q-uhd-wireless-media-center?variant=1079261233180
Almando Multiplay Surround decoder - https://almando.com/index.php/almando-category/multiplay-surround-decoder/almando-multiplay-surround-decoder.html
I am sort of leaning towards the Almando, but hesitant as the Axiim seems to have a newer interface and can transmit directly to the speakers, but then I lose my Core as I do not think the Axiim has an optical in or a way for me to get the Core through it.
Almando seems a little more function over style and allows a lot of fiddling, but Axiim looks to be more up to date and frequently supported with updates. I think any audio lag passing through the video etc through the Axiim can be countered via app settings.
Hmmm ... I think either solution works, but the Almando lets me keep my core and Transmitter 1 functioning I guess.
What do you guys think?
Mikipedia? ... do you still use the Almando?
Thanks!
Mikipedi4 on Twitch: https://www.twitch.tv/mikipedi4
Mikipedia on Intagram: https://www.instagram.com/mikipedi4/
Old: Beosound 9000 mk3, Beolab 3's, Beovision Eclipse, Beolab 1's, Beolab 2, Beovision 10-46, Overture 2300, beolab 8000's, Beolab 4000's, Beovision avant 32" etc. etc.
Thanks for the quick replies fellas :)
Aussie Michael, I assume you are talking about the TM as in the Transmitter 1 is not a receiver and no the Almando box?
Just double checking. :)
