Beolab 50, Beolab 8000 x 2, Beolab 4000 x 2, BeoSound Core, BeoSound 9000, BeoSound Century, BeoLit 15, BeoPlay A1, BeoPlay P2, BeoPlay H9 3rd Gen, BeoPlay H6, EarSet 3i, BeoVision Eclipse Gen 2 55", BeoPlay V1-40, BeoCom 6000 and so much else :)
leosgonewild:You can buy a 65” LG oled from 2018 for 2300€ Or go for a 75” even. And invest in a proper surround system instead. You can mount the LG in an old B&O stand.
@Michael
Calm down - and keep your Avant 55.
Millemissen:@Michael Calm down - and keep your Avant 55. MM There is a tv - and there is a BV.
Michael: Do you mean that there is news coming? I changed my phone to the XS Max recently and I want to jump on the OLED train sometime. I do like the Avant a lot but the benefits of OLED is also nice and I don’t like hanging on to the same device for too long. I like change :)
I do not know anything about ‘news’!
If the OLED technology in a pure LG tv is more important to you than the benefits - that you yourself descrided - of an Avant 55, you will need no further advice.
Just do it!
Millemissen:I do not know anything about ‘news’! If the OLED technology in a pure LG tv is more important to you than the benefits - that you yourself descrided - of an Avant 55, you will need no further advice. Just do it! MM There is a tv - and there is a BV.
I have had the original Avant 55, loved the design but had issues with dirt behind the screen. I also wasn’t happy with the edge lit display. I moved to the Avant NG and it was a more capable 4K TV air was crippled by buggy software. So I recently moved to the Eclipse and I have found it so much better than the Avant. It is far more responsive, sound much better and the display is far better. Obviously there is the issue of is it worth it. But just basing it on the tv, the Eclipse is far better and I’m far happier with it.
Michael: Just do what?
Just do what?
Just get the stock LG ;-))
To me it seemed that you don’t think, that the integration with the B&O parts and the Sound Center as a unit is worth the money, when considering the Eclipse.
Also the fact, that they did not put a 2018 screen into it, was a concern of yours.
Therefore that could not be my advice!
Waiting for something ‘new’ iseems also not to be an option....or ———- whatever ‘new’ would mean.
(That however, is my personal option - untill then I’ll enjoy my Avant 55 and the setup that I have around it).
Looking forward to read about how you decide to get on.
I prefer the Sony myself and the latest reference one has the ability to use the "acoustic surface" as a centre channel in a multi channel setup. Ingenious.
I wonder if you can plug in the stock LG if it gives you the B&O bits , or do they install certain B&O software in the LG. You can see certain android packages installed on the BV14 for example.
Beovisions have always been more expensive than the price of the parts.
The screen an rendering of the picture
Sound processing including surround plus...plus
The Stand
The integration with a B&O. AV System
PUC management and 3rdParty integration.
Beoremote menu uplink.
Always thought that that premium was worth it but started to gulp with the Eclipse. Main issue for me was/is the Cr@ppy home screen (smart screen). It is shocking and screens LG. B&O MUST get back to their elegant, simple black and white intuitive menu screen. The other issue I have is that pure 3party products that don’t integrate with a PUC or direct control are a real PITA.
Like the TV, hate the price, would hate to go to a non-B&O TV with a system like mine.
I'll gonna throw a new had in the ring: ;-)
At friday I fell in love with the new Samsung 8k QLed!
The picture Quality is far far away from any other TV I've seen! Even Loewe is peace of a cake (I hope this is the right english subscription) compared to this! Even SD (normal TV or DVD) looks great! And if you start watching several 8k streams from youtube - you won't be able to close your mouth!
You have to look for the Q900 Series - it's new since two or three weeks now in Germany.
I thought that 75" would be far to big - I came from the 46" Loewe - but it is Ok - far more: How could we've lived with these small tiny TVs? ;-)
For the connectivity I use a Bluetooth receiver for my BS9000 and connected this to the TV (build in Bluetooth).
Or use the Almando System with the ARC from the TV.
I have had the LG OLED 910, and the C7,
I switch to the Eclipse and have never looked back.
Best tv by far I have ever had, a no brainer in my opinion.
LG and others are cheaper, yes but that is the only thing they have going for them.
Lots have been said, I will just add Net radio, which I use also on the Eclipse.
And Again the Beoremote is much better the LG magic remote.
My parents have the AVANT, which is really good, the Eclipse is better tough.
And it is a 2017 panel, and processor. Not much have happen here in 2018. You could choose to wait to see what happens in 2019.
Emil Jensen:I have had the LG OLED 910, and the C7, I switch to the Eclipse and have never looked back. Best tv by far I have ever had, a no brainer in my opinion. LG and others are cheaper, yes but that is the only thing they have going for them.
If you look at the picture quality the Eclipse is the C7,
Also the LG B7-E7-G7 and W7,
They are the same high-end and low-end.
And I would bet that no one on this forum can see a difference to the 2018 models. Same panel different software and processor.
In any case the difference between LG/Panasonic/SONY/Philips all with OLED is so small, the avarage user cannot see a difference. Loewe sadly have some bad adjustments on theirs.
In my personel opinion, I would never recommend Samsung, as LCD screens are bad compared to OLED. And I do not care that they call is QLED or it have 8K, it is still LCD.
But keep in mind the x7 Series ist outdated - actual is x8 (B8,C8,W8) Series - I think from 2018 ;-)
Yeah, the Samsung ist LED not OLED - nothing can burn in, no special mechanism is needed to prevent burn in - sorry, but I think OLED is absolutely overrated!
I don't like the OLED picture that much - For me the contrast is too much, the picture is unreal!
My wife want's the LG W8 (the Wallpaper), I thougt the Loewe Bild 7 would be better and now we have the Samsung ;-)
I'd say: Give it a try and decide then . . .
The plan as I understood was to use new 2018 panels, but it cost a lot to get a special version from LG,
Plastic is different, Box is different, software and an ekstra tuner and no speaker is different.
So when the difference from 2017- 2018 was almost none, they saved that cost. I would say that it was a good choice.
Actually I bought the Eclipse well knowing what the 2018 had to offer.
Anyways if I were you I would wait 1,5 month and see what 2019 have to offer.
Would save much regret.
Emil Jensen:The plan as I understood was to use new 2018 panels, but it cost a lot to get a special version from LG, Plastic is different, Box is different, software and an ekstra tuner and no speaker is different. So when the difference from 2017- 2018 was almost none, they saved that cost. I would say that it was a good choice. Actually I bought the Eclipse well knowing what the 2018 had to offer. Anyways if I were you I would wait 1,5 month and see what 2019 have to offer. Would save much regret. Beolab 20, Beolab 17, Transmitter 1
Michael I do not think you know have much different Eclipse is from C7 in Hardware.
It is a completely different model.
So the C8 do not have a different backing, at least not more different from C7 to the Eclipse,
If you still thinking the soundcenter and the panel as two pieces that can work from each other, then you are on the wrong path.
The eclipse is as a complete tv as the Avant.
One thing is cost, but there have only been very minor improvement from 2017 - 2018, it is still the same panel.
I cannot see what you think you are missing?
Also I believe that B&O pays more for the TV part, then we have to give for a C8 on the market.
You can compare cost as much as you want, but there is nothing on the market as complete as the Eclipse, so there is really no brand to compare price with.
You compare product in very different price classes, and that you can, but it is silly to do in many cases.
Sorry Michael,
You did not make me upset, I am not so good on paper, I am better at discussion in real life.
I understand your view, as it is the same as mine.
That is also the reason why I have tried several brands, both in speaker, Receivers and TV the last 15 years.
Now I have gone for B&O and I have never been more satisfied. simple elegant and well working.
I also understand that you want the picture to be as good as possible. But it isn't. Sony as I read it takes the lead there.
But the difference now is not as before, most OLED tv's are great, and the last 1% you would not notice.
But the other great things with B&O you will notice, as you already have the AVANT.
My point is I drive a VW, I would like a Mercedes, but don't have it because of price. But I am well aware of what I am missing. And if you buy a LG C8, when you have been used to a AVANT you will too.
Emil Jensen: Sorry Michael, You did not make me upset, I am not so good on paper, I am better at discussion in real life. I understand your view, as it is the same as mine. That is also the reason why I have tried several brands, both in speaker, Receivers and TV the last 15 years. Now I have gone for B&O and I have never been more satisfied. simple elegant and well working. I also understand that you want the picture to be as good as possible. But it isn't. Sony as I read it takes the lead there. But the difference now is not as before, most OLED tv's are great, and the last 1% you would not notice. But the other great things with B&O you will notice, as you already have the AVANT. My point is I drive a VW, I would like a Mercedes, but don't have it because of price. But I am well aware of what I am missing. And if you buy a LG C8, when you have been used to a AVANT you will too.
:) yes, arguing/discussing online always is harder than in real life.I do enjoy my avant and I bought it, also after using other high quality stuff from different vendors. I do sometime miss how clean my setup was before though (beolab 8000 + samsung led screen with super thin metall frame) it looked stunning but I had to use a receiver and different remotes or a harmony remote that never really worked well. I enjoy how integrated the avant is even though it took three units before I got one that was really good!
I don't have a need to buy a new set but I get bored sometimes and want something new and also not keep stuff too long. I already had the avant for four years. Time to move on soon probably. I hear Sony makes great OLEDS but I think LG still has the advantage in the design, WebOS and stuff like that. But I also gather that some OLEDs are too high in contrast making everything look too colorful. I enjoy the subtle colors on my Avant and it is more genuine and cinematic looking. Popping colors is nice but not always what the director or photographer intended - so a lot of the contrast race is not "genuine". However, the black levels are, and the thin and modern design is. Sigh, will wait a bit more and see what I do :). I also do custom installations with much higher cost devices at work, using crestron and other integration tools to send video to several projector systems, split and send to different places or modify room design and even shape. I would like to do that at home too but my home is a home and nothing else :D
Flatpanelshd say the picture quality of the C8 is an improvement over the C7.
Other than that, wasn't it said here 6 months or so ago that there was to be no more new Tv's from B&O or have I just made that up?
Ban boring signatures!
Emil Jensen:Anyways if I were you I would wait 1,5 month and see what 2019 have to offer.
BeoNut since '75
Prepairing for HDMI 2.1 and 8K - features we can’t live without.
Every year the same.....keep the business alive.
Millemissen: Prepairing for HDMI 2.1 and 8K - features we can’t live without. Every year the same.....keep the business alive. MM
....or alternatively they could continue to improve the picture quality and OS - as good as oled may be it is not yet perfect and there is still room for improvement!
Puncher: Flatpanelshd say the picture quality of the C8 is an improvement over the C7.
Lot of effort to get the same-old same-old from Sky, BBC, Coronation St and other dross
Mr 10Percent: Puncher: Flatpanelshd say the picture quality of the C8 is an improvement over the C7. Lot of effort to get the same-old same-old from Sky, BBC, Coronation St and other dross
- true enough!
Perplexes me that in 2018 were still *that* obsessed with picture quality. Smh. Seriously. It’s so marginal now. There were huge leaps in picture quality between the years from 2005 through 2015, but anything since is relatively marginal. For instance, the “old” BV7-55 MK2 still has a superb picture and so does the BV12-65.
moxxey: Mr 10Percent: Puncher: Flatpanelshd say the picture quality of the C8 is an improvement over the C7. Lot of effort to get the same-old same-old from Sky, BBC, Coronation St and other dross Perplexes me that in 2018 were still *that* obsessed with picture quality. Smh. Seriously. It’s so marginal now. There were huge leaps in picture quality between the years from 2005 through 2015, but anything since is relatively marginal. For instance, the “old” BV7-55 MK2 still has a superb picture and so does the BV12-65.
On the other hand, if you can make it better at a similar price then why wouldn't you?
moxxey:Perplexes me that in 2018 were still *that* obsessed with picture quality. Smh. Seriously. It’s so marginal now. There were huge leaps in picture quality between the years from 2005 through 2015, but anything since is relatively marginal. For instance, the “old” BV7-55 MK2 still has a superb picture and so does the BV12-65.
moxxey: Perplexes me that in 2018 were still *that* obsessed with picture quality. Smh. Seriously. It’s so marginal now. There were huge leaps in picture quality between the years from 2005 through 2015, but anything since is relatively marginal. For instance, the “old” BV7-55 MK2 still has a superb picture and so does the BV12-65.
As a side note, it still amazes me that with all the science, R&D etc. going into micro-electronics etc......all the manufacturers still make cr@ppy user interfaces fit for kindergarten class, remote controls and on average, poor integration with other products.
@@Chris Townsend
With this in mind:
You could have stayed at the Avant 32" and VHS :-))))
(sorry for my crappy syntax)
Puncher: On the other hand, if you can make it better at a similar price then why wouldn't you?
Yes, but you miss my point. It's not just about "picture quality". If it was, we'd all go for an LG. It's more about the overall experience.
Michael: I really do not agree. Oled is quite new on big screens and a lot is happening there.
You think? When I look at the latest OLED screens they just look really sharp to me (compared the smooth BV12-65/BS4) - and then you need a more expensive 4K source to get the best from them anyhow.
There were far more jumps in panel improvements a few years ago.
I just don't get why middle-aged men sit here and talk about improvements in picture quality in 2018 as if it really makes such a difference to their visual experience - there really isn't a stunning improvement between 4K to HD, in my experience, compared to HD versus SD.
moxxey: Michael: I really do not agree. Oled is quite new on big screens and a lot is happening there. You think? When I look at the latest OLED screens they just look really sharp to me (compared the smooth BV12-65/BS4) - and then you need a more expensive 4K source to get the best from them anyhow. There were far more jumps in panel improvements a few years ago. I just don't get why middle-aged men sit here and talk about improvements in picture quality in 2018 as if it really makes such a difference to their visual experience - there really isn't a stunning improvement between 4K to HD, in my experience, compared to HD versus SD.
Im 33 and I enjoy technology. The thing with 4K is not only the resolution but color depth and the different ways to get that, including not only color but also luminance. I don't watch a lot of different panels all the time, but if I buy one I want one that is up to date. Everyone is different but for me current tech is always more fun to buy than older tech. Even if it is probably very good for what it was then.
