Beovision 8 and electric curtains.
This post has 25 Replies | 3 Followers
SJensen
Posts 8
SJensen Posted: Tue, Nov 20 2012 2:42 PM
Normal 0 false false false DA JA X-NONE
I have just bought a Beovision 8-40 and completely love it.
There is just one thing that really bothers me and that's the electric curtain effect. I use the DVB-modul in the TV and it takes quite a while to start up. But the electric curtain effect does not take that in account, so when the curtains glide aside it takes about 20-25 seconds before i se the picture and hear the sound. That really spoils the effect and i think that's such a pity.
Does anyone in heir have a solution for delaying the curtains effect when the TV starts up?
Hope someone can help!?
Paul W
London
Posts 1,810
Paul W replied on Tue, Nov 20 2012 3:20 PM
Elephant is the man for this!!!
tv800
Posts 4
tv800 replied on Tue, Nov 20 2012 3:40 PM
Hi .... I also have a BV8-40 but no issues with the curtains ... They only "open" when the picture is ready. This was default, and I would also imagine that this is the way it is intended :-) I recommend you contact the dealer and make a complient.
elephant
AU
Posts 8,219
elephant replied on Tue, Nov 20 2012 8:18 PM
Paul W:
Big Smile
I shall do some timing tests ... I imagine it is a fixed delay
I have not seen any every day user controls to change the delay, or turn it off
but I will time the curtain and the sources for you
BeoNut since '75
Paul W
London
Posts 1,810
Paul W replied on Tue, Nov 20 2012 11:12 PM
AWESOME!!! I knew that you were the man, Mr Elephant :) :) :)
David Coyne
Sydney, NSW, Australia
Posts 305
Paul W:
Clearly da Elephant is da man!  He'd better come to our next party along with you Paul W!!
Also have a BV8-40 and the curtains work fine...
Hope you get the problem fixed,,, would be interested to know what the issue is?
My complaint with the BV8 is a 'judder/shudder' on the picture at times... do I need to turn off "MOVIE" effect?
Beovision 8-40, Beocentre 6-26, Beocentre 2, Beolab 9's, Beogram 7000, Beogram 9500, Beo 5, Beolit 1000, 800, 700, 600, 400, Beocom 6's, Beotalk 1200
SJensen
Posts 8
SJensen replied on Wed, Nov 21 2012 11:31 AM
Sounds perfect!
I look forward to hear what you find out!?
I have taken time on how long the TV takes to start:
From I press the TV button on Beo4 it takes approximately 16 sec till the curtains open, and I see the gray screen with the black clock.
After 26 sec the grey screen disappear and the TV screen goes completely black and first after 45 sec the picture appears and so does the sound. Completely ridicules!
How long does it take to start for you other guys who also have a Beovision 8-40?
Raeuber
Germany
Posts 2,542
Raeuber replied on Wed, Nov 21 2012 12:03 PM
Hi SJensen,
the behaviour you describe is the same I had when I got my BV 10-40 in 2009. The ugly grey screen with the clock disappeared after a software update in 2010. The actual software of BV 10 and also BV 8 is build 227. So make an update of your BV 8-40 by your dealer.
After the update you don´t see the clock any more, but it still lasts more than 30 seconds until the electronic curtain open and the picture appears.
Regards
Räuber
SJensen
Posts 8
SJensen replied on Wed, Nov 21 2012 12:42 PM
Hallo Räuber
Thanks for the reply.
I just called my local B&O store, but the man I talked to didn't know anything about a software update?? He though still offered me to come by with my Beovision 8 and he would then take a look at it.
Can you tell me how to look which software build is installed now on my TV?
BeoGreg
South of France
Posts 1,417
BeoGreg replied on Wed, Nov 21 2012 12:46 PM
Raeuber:
Hi SJensen,
Regards
Räuber
Raeuber,
I think our friend needs to update the Dvb-hd modul not the tv to get reed of the clock.
You need to go on B&O site and use a Usb stick to download. The picture will even appear faster.
Gregory
SJensen
Posts 8
SJensen replied on Wed, Nov 21 2012 12:53 PM
I have the most recent update for the DVB-HD modul: Version 0.1.9.9. Smile
Raeuber
Germany
Posts 2,542
Raeuber replied on Wed, Nov 21 2012 12:54 PM
You can see the software version as follows:
Press MENU twice
Mark OPTIONS (don't press GO)
Press 0 0 GO
You see the SERVICE MENU
Then select MONITOR, MONITOR INFORMATION
Now you can check the software version. I assume you have Build 127 or so.
Your dealer can update the software with a special software and his notebook.
Regards
Räuber
Raeuber
Germany
Posts 2,542
Raeuber replied on Wed, Nov 21 2012 12:58 PM
BeoGreg:
Raeuber:
Hi SJensen,
Regards
Räuber
Raeuber,
Gregory
Hi Gregory,
no, the ugly clock is caused by the software of the beovision, not by the software of the HD module!
And: With the actual software build 227 and HD module software 0.1.9.9.0 my BV 10-40 still takes more than 30 seconds until the curtain opens!
/Räuber
elephant
AU
Posts 8,219
elephant replied on Wed, Nov 21 2012 1:02 PM
SJensen:
Sounds perfect!
So I arrived home early (i.e. 11pm) and so I am doing some tests for all of us Smile
First simple test to establish a baseline on my BV8-40 ... note I was using my left hand to start an iDevice stopwatch and my right hand to start the [Beo4] keys ... and then pressing the iDevice lap timer with my left hand at various stages ... so plenty of room for error ... but the "scale" of the difference is probably what we are really after !
[A.MEM] to start of music from speakers (I have two attached BeoLab 3s) ... 7.5 seconds (speakers had been warmed up by several false starts)
[RADIO] to start of noise Smile from speakers .......................................................... 8.5 seconds the speakers clicked, ~13.0 seconds the sound of radio
[CD] to start of music ................................................................................................ 8.5 seconds to speaker click, 13.5 seconds to sound of CD
Interesting then is that around ~2.0 seconds there is a soft click which seems to be the BV8-40 activating
So now let's test the video aspects of the BV8-40
[TV] to start free to air analogue ............................................................................. 1.1 seconds to soft click, 7.7 seconds to speaker click, 17.0 seconds to start of curtain opening
[DTV] .... hmmm that was interesting !
1.6 seconds to soft click
7.8 seconds to speaker click
16.5 seconds to Bang & Olufsen logo in gray on bottom right hand corner
33.5 seconds to curtains parting ... sound a second or two after that !
[LIST] [PC] (having woken up the MacMini in the background)
2.2 seconds to soft click
8.2 seconds to speaker click
21.5 seconds to curtains parting to display desktop
[LIST] [V.AUX] for Foxtel
(missed the soft click - too much family chatter during important scientific experiments *tsk* *tsk*)
17.1 seconds to curtains parting
[LIST] [DVD-2] for the PS3 (activated on the background)
8.4 seconds to speaker click
21.2 seconds to curtains parting
[DVD] for the ATV ... which might be delayed by its own activation so we shall see:
~ 2 seconds to soft click
7.9 seconds to speaker click
27.2 to flashing of backplane (ATV startup?) and then curtains open and ATV's screen appears
So in summary
  1. approximately 2 seconds to activate the BV8-40 electronics (the soft click)
  2. approximately 7.5 to 8.5 seconds for the BeoLab 3s to click on -- if they were not attached would the process be faster ? or more frustrating since there was no halfway mark indication of progress ?
  3. approximately 13 seconds to pure audio functions with no screen activation (although there was masterlink traffic and Beosound 4 start-up delays in here !!)
  4. approximately 17 seconds for a video source that was already "active" i.e. free to air analogue, and the FOXTEL which is also analogue via a SCART cable
  5. between 21.2 and 27.2 seconds for a digital video source via HDMI where the digital source had been activated it was the low end, and the high end for where the source may have been being activated -- so I repeated the ATV test with the ATV still active and got 21 seconds to the display of the ATV screen, so the 5.0 seconds does seem to be the handshake to activate and recognise the ATV if it is "cold"
  6. the big outlier - the digital TV free to air .... a whopping 34 seconds but a nice sexy B&O logo to keep you waiting at the 16.5 second mark indicating the TV display was "alive"
  7. I also include a test of switching from [TV] to [DTV] ... and got 4 seconds to channel information menu appearing and 7 seconds to actual video signal appearing ... confirmation that accessing the digital tuner adds some 7 seconds to the basic processes
At no time have I see a gray screen and black clock ... I presue this means we are at different software levels.
My BV8-40 is hardware type C23, LCD panel type LTA400HG02 (whatever that means!) ... and I can't remember how to retrieve the software level
Tomorrow I might repeat some of these source tests on my BV8-32 just for comparison !
BeoNut since '75
SJensen
Posts 8
SJensen replied on Wed, Nov 21 2012 1:03 PM
This i how my Monitor Information looks. I can't seem to se anything about the software??
elephant
AU
Posts 8,219
elephant replied on Wed, Nov 21 2012 1:07 PM
Raeuber:
Press MENU twice
Press 0 0 GO
Regards
Räuber
Thank you !
So the software build for my timing tests is/was ....... 227
And it also says DVB HD .... 0.1.9.9
BeoNut since '75
elephant
AU
Posts 8,219
elephant replied on Wed, Nov 21 2012 1:09 PM
David Coyne:
I would be happy to do so ... better strengthen the floor boards !!!
BeoNut since '75
Raeuber
Germany
Posts 2,542
Raeuber replied on Wed, Nov 21 2012 1:16 PM
Sorry, but the software build version is only shown with newer software versions, your screen shows only the versions of the different modules.
My BV 10-40 with software build 227 shows "BUILD 227" and also the versions of the modules:
PW 328: 04.66a
FEP: 04.54a
FEP BOOTLOADER: 00.03b
FA MODULE: 00.02.02
STB TABLE: 05.29b
SYSTEM MODUL: 50.06a
SM HW: 4.4
BtB MODULE: n/a
DSM FEP: 05.27a
DSM DSP: 05.24a
DVB HD: 0.1.9.9
TCON: 20090723
/Räuber
elephant
AU
Posts 8,219
elephant replied on Wed, Nov 21 2012 1:19 PM
SJensen:
Mine NO.s read:
TYPE 9562
ITEM 1956204
SERIAL 22363xxx
OPTION 2
BUILD 227
PW328 04.66a
FP 04.54a
FEP BOOT 00.03b
FA MODULE 00.02.02
PUC 05.49b
SYSTEM MODULE 20.06v
SM HW n/a
BtB MODULE n/a
DSM FEP 05.27a
DSM DSP 05.24a
DVB HD 0.1.9.9
TCON 20091123
                 230839
So a detail that is greater than yours .... another indication that your BV8-40 is a lower level of software from mine ?
Although the DVN HD seems the same, the SYSTEM MODULE is clearly an early version than mine (which was updated when I had my problems back in April-June)
BeoNut since '75
SJensen
Posts 8
SJensen replied on Wed, Nov 21 2012 1:23 PM
Yes okay
That tells us that the software really needs to be updated Stick out tongue
Thanks for you help and I let you know if the software update helps or not!
elephant
AU
Posts 8,219
elephant replied on Wed, Nov 21 2012 1:29 PM
SJensen:
Yes okay
My pleasure ... it was an interesting exercise ... and I got to understand my BV8-40 a bit better Smile
BeoNut since '75
SJensen
Posts 8
SJensen replied on Wed, Jan 2 2013 8:47 PM
Today I got my local B&O dealer to update my BV8 and the problem is now solved!
The employee really knew what he was talking about and the service was fantastic!
Aussie Michael
Melbourne, AU
Posts 3,730
I don't mean to hijack but I was wondering those people who have Beovision 8 how has the quality of the tv set lived up over time ? With particular emphasis on the soft touch exterior.
I love the curtains!
elephant
AU
Posts 8,219
Had a white one for ... 3.5 years ... And it is just fine.
But since it was an ex-something model, it was quite dirty when it arrived, but scrubbed up very nicely, thank you very much :)
BeoNut since '75
Aussie Michael
Melbourne, AU
Posts 3,730
Thanks Ed. I love the white one.
Heribert
Vorarlberg / Austria
Posts 804
mickhoog:
I have a 8-40 since 2009 and a white 8-32 since 2010. I do love both of them Nd still prefer the picture of the 8 over the one of the BV10. Soft touch exterior is no problem. It probably becomes dusty a little quicker, but might also be that you just see it better. In general it is not more dust than on the screen itself.
BV 11-46  / Beoplay V1 -40 / Apple TV 1+3 / Beosound Essence MK2 / BL3 / 2* BL11 / BL 6000 / BL 12-1 / BL 2000 / 3 * Beo4 /BL Converter 1611
Page 1 of 1 (26 items) | RSS
