S8 Connection Hub
Matt
UK
Posts 3
Matt Posted: Fri, Dec 14 2018 8:28 PM
Hi all, I have been given a Beolab 7.1 speaker and would like to connect to my Samsung smart TV. Problem is the TV has no headphone jack to connect to so I'm currently looking at getting the S8 hub which is discontinued. Anyone know where I can get hold of one of these please as I've drawn a blank looking for one so far.
leosgonewild
Helsinki, Finland
Posts 2,373
Send me a pm. I have one extra I don’t need Big Smile
Matt
UK
Posts 3
Matt replied on Fri, Dec 14 2018 9:55 PM
Thanks, pm sent.
Mikipidia
Posts 2,169
Mikipidia replied on Sat, Dec 15 2018 1:27 AM
the ''new'' version is now just the ''Connection Hub'', just an fyi
Mikipedi4 on Twitch: https://www.twitch.tv/mikipedi4
Mikipedia on Intagram: https://www.instagram.com/mikipedi4/
Old: Beosound 9000 mk3, Beolab 3's, Beovision Eclipse, Beolab 1's, Beolab 2, Beovision 10-46, Overture 2300, beolab 8000's, Beolab 4000's, Beovision avant 32" etc. etc.
leosgonewild
Helsinki, Finland
Posts 2,373
The hub is a great device. You can connect a audio device also. That way you can use the speaker with the tv off.
Smile
Steve at Sounds Heavenly
The cable workshop, Leics, UK
Posts 2,165
Hi Matt,
Welcome to Beoworld!
Once you have the Hub, the connections are straightforward:-
Please use an optical cable from the TV to the Hub: https://soundsheavenly.com/tv-input/premium-braided-toslink-optical-cable-with-metal-plugs
Please use this cable from the Hub to the Beolab 7-1 speaker: https://soundsheavenly.com/bang-olufsen/rj45-to-powerlink-compatible-all-in-one-cable-convert-new-2013-ethernet-powerlink-to-traditional-8-pin-din-powerlink
Kind regards, Steve.
Steve.
www.soundsheavenly.com
Matt
UK
Posts 3
Matt replied on Tue, Dec 18 2018 10:37 PM
Hi Steve,
I've ordered the rj45 cable from the link, looking forward to some decent sound from the TV.
Cheers, Matt.
Posts 2,165
Thanks Matt,
I will email you directly to confirm shipping details in a moment.  Please ask if you need any further help.
Steve.
chucky
Posts 331
chucky replied on Thu, Dec 20 2018 10:25 PM
Is it possible to use the new hub as powerlink switch between an ML TV and a Beosound core so you can share speakers? If I look at the excellent manual than it should be possible powerlink in and out.
Tx!
Page 1 of 1 (9 items) | RSS
