Hi all, I have been given a Beolab 7.1 speaker and would like to connect to my Samsung smart TV. Problem is the TV has no headphone jack to connect to so I'm currently looking at getting the S8 hub which is discontinued. Anyone know where I can get hold of one of these please as I've drawn a blank looking for one so far.
Thanks, pm sent.
the ''new'' version is now just the ''Connection Hub'', just an fyi
Mikipedi4 on Twitch: https://www.twitch.tv/mikipedi4
Mikipedia on Intagram: https://www.instagram.com/mikipedi4/
Old: Beosound 9000 mk3, Beolab 3's, Beovision Eclipse, Beolab 1's, Beolab 2, Beovision 10-46, Overture 2300, beolab 8000's, Beolab 4000's, Beovision avant 32" etc. etc.
Hi Matt,
Welcome to Beoworld!
Once you have the Hub, the connections are straightforward:-
Please use an optical cable from the TV to the Hub: https://soundsheavenly.com/tv-input/premium-braided-toslink-optical-cable-with-metal-plugs
Please use this cable from the Hub to the Beolab 7-1 speaker: https://soundsheavenly.com/bang-olufsen/rj45-to-powerlink-compatible-all-in-one-cable-convert-new-2013-ethernet-powerlink-to-traditional-8-pin-din-powerlink
Kind regards, Steve.
Steve.
www.soundsheavenly.com
Hi Steve,
I've ordered the rj45 cable from the link, looking forward to some decent sound from the TV.
Cheers, Matt.
Thanks Matt,
I will email you directly to confirm shipping details in a moment. Please ask if you need any further help.
