Hello
For over two years now I'm been plagued by software problems with my various bang and olufsen products, including the beosound 5, moment , beoplay 1. This necessitated various correspondence with Denmark. After multiple requests a teleconference with Denmark was set up and my moment worked for about 6 weeks without any issues. Short version, stopped working properly and I took the product back for a refund.
My latest issue is with my Avant 55 Mk 1 (which is still less than three years old and under warranty). My Avant is integrated with a CORE using the B&O app to access NAS, TuneIn and Deezer.
The issues now are:
1. Music will not play via Avant and connected speakers for more than an hour without switching off (we've checked timers and its nothing to do with that).
2. If the avant/ core is joined with other multi room products music starts to cut in and out and is not useable.
Technicians have visited a couple of times and suspected a software platform fault. They have spent hours and hours testing all equipment.
I've emailed Denmark about this several times, I've not received any response at all. Just silence.
The technicians participated in a teleconference with Singapore team to discuss. Singapore confirm it is a software platform issue that is incompatible with other products.They don't know if an update will be coming for the Avant Mk1 (even though my TV is only 2.5 years old and bought new from the show room).
A work around is to connect my beolabs directly to the core, though this will mean i can no longer have my speakers work with the TV.
Im tempted to try and return the TV and the electronic wall bracket and ask for a refund. Interestingly just called the only Showroom left in the country who suggested that if I can watch tv then there's no issue and there are possibly no grounds to suggest refund!
Any suggestions? I've run out of patience with the ongoing software issues.
David
Beovision 8-40, Beocentre 6-26, Beocentre 2, Beolab 9's, Beogram 7000, Beogram 9500, Beo 5, Beolit 1000, 800, 700, 600, 400, Beocom 6's, Beotalk 1200
Razlaw:I recently purchased a Core. Also have an Essence MK2 and a V1. I also experienced the cutting out of sound when joking the V1 yo the group. Today I played around with the settings on the V1. The three products are in three different rooms. I went in to the “link” settings of the V1 and linked it to the Essence and the Core. Also selected not in the same room in the V1 settings. It seems to have solved the problem and all seems to be working now.
vlohjr1: Razlaw: I recently purchased a Core. Also have an Essence MK2 and a V1. I also experienced the cutting out of sound when joining the V1 to the group. Today I played around with the settings on the V1. The three products are in three different rooms. I went in to the “link” settings of the V1 and linked it to the Essence and the Core. Also selected not in the same room in the V1 settings. It seems to have solved the problem and all seems to be working now. I experience the same as well
Since changing the settings in the V1, all three systems have been playing for a couple of hours with no problems. Have also tried turning on and off repeatedly. At least in my system, it seems that I may have solved the problem.
w5bno123:I believe there is a software issue post Apple Airplay 2 update and a new version is coming soon.
Can you confirm this?
I haven’t updated my Essence (yet) - I won’t need AirPlay 2 there anyway.
But I occasionally do need to redirect something airplayed to my tv’s (the NL function).
This works very well - in fact all works well.
P.S. My Essence is connected to my two tv’s....not integrated with.
So - if there really should be a problem there (with the latest update), I guess I’ll wait a while with updating (or don’t do it at all).
I have the same issue as you David, the Airplay 2 update has broken the multiroom functionality with the Avant Series 1. I have a Moment integrated with the Avant, but even when I take this out, the TV also can't connect to the multiroom stream without cutting out. For some reason, if you initiate the stream from the TV, rather than another room - it seems to work.
Let's just hope that Denmark choose to update the software, but given that the last update was in mid 2017, I'm now a bit worried about the longevity of the Avant platform.
Hi everyone,
I can also confirm, post AirPlay2 update of my A9, A6, and M5 I have the same issues.
If I play something using the B&O app to either the A9, A6, M5 and then join in with the Avant gen1 the sound cuts in and out. If I am playing something on the Avant (TV, HomeMedia...) I can join in the other items with no issue.
I also have a BeoSystem4 connected to a projector and it behaves the same as the Avant, in other words, it affects all BeoSystem4 platforms.
Not great timing for the Christmas holiday and party season!!! Here's hoping for a quick resolution to this one...
BeoVision Harmony77 G1 with BeoLab18 x 4 & BeoLab14 4.1 (7.1.4); BeoPlayA9 Mk4; BeoSound2; BeoSound1 x 2; BeoPlayH95; BeoPlayE6; BeoPlayH3 ANC
..and it all started 20 years ago with a pair of B&O A8 Earphones...
Same here with my V1. After maybe 20 minutes or so the trouble starts. Have contacted BeoSupport which recommended cutting the V1 off power for a night. Didn't help.
It seems that they have to do some overtime work correcting this sw in the next few days - glad I did not update my Essence yet 😉
Just an update for everyone...this is still not fixed so I have been in contact with beoplay/beocare. Unhelpful as always, refusing to acknowledge that it is an issue with the lastest software and telling me it is a BeoSystem problem. As a last resort I asked if I could have the software in my A9 A6, M5 rolled back for the Christmas break but they said this was not possible...so annoyed!!!
Hi Yendys
At least you received a reply, some two months on after sending an email to BeoCare, positing on their facebook page and sending a message via messenger, I've received no reply at all.
What used to be a premium brand now rather behaves like a secretive government agency providing no responses and admitting no liability. If you don't respond the problem doesn't exist.
As more time goes by I become more and more infuriated with the lack of care and responsibility.
I know there are software problems, they just have to say so! Clearly the strategy of bringing software back in house has had limited success. Clearly the multi room functionality seems to only work now if you have a couple of products all of the same generation. If you start combining more than a couple of products the system and software seems unable to manage. The whole point of staying with the brand was seamless integration, not weekends of endless resetting of products, deleting of products, developing 'work arounds' , all to be able to listen to an album!!
I've recently given away my Beosound 5 with a 1TB and CD ripper because it was unsellable. I took my Moment back due to software problems, now the TV that is still under warranty isn't working properly. AS the TV still functions as a 'TV' though there is 'no problem' as far as B&O are concerned. If I had a more up to date TV they say it would be all ok! Seriously I'm going to spend 15k on a TV when my old one is still under warranty?!
Happy New Year!
w5bno123:There is a service solution for audio systems available now, request it via your dealer. Expect the general release to rollout first few weeks of January.
Best regards - Dyssegaard
Living room: Beovision Eclipse 55, Beolab 3 / R1 (back), Beolab 2 / R1 (sub), AppleTV 4K. Bedroom: Beovision 11-40, AppleTV 4. Home office: Beoplay M5. Kitchen: Beoplay M5. Travel: Beoplay H8, Beoplay A1. NAS: WD My Cloud Home / Plex DLNA Server.
David,
Try hard wiring the core & Avant rather than wireless. I have been having major drop out issues with my BV11-55 when joining it to multiroom music. It would play ok for 30 min or so when joined to ONE other product before drop outs began - and if I attempted to join any more products it would drop out instantly.
Yesterday I plugged in the BV11 with an Ethernet cable and it does seem to have resolved the constant intermittent drop outs. Additionally I can now join further products to the network :-)
Furthermore, I have a Core, also hardwired, running a BL11 & BL8000s in my dining room and it never plays up or drops out.
I have found great success with hard wiring , but that may not be that easy for all people
Too bad that hard wiring won't be a fix for the M3
Razlaw:After yesterday’s software update to the M5 everything seems to be working as it should, if I start with the M5.
What is the latest version of the M5 software?
Do you know what the update included other than bugfixes?
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
1.18.27862.1894486813
Razlaw:I have been having the same issue with my V1, Core, Essence, and M5. After yesterday’s software update to the M5 everything seems to be working as it should, if I start with the M5. Joining the V1 to the already playing M5 has worked with no problems. Hopefully the same software fix will soon come for the Essence and Core. Also, don’t know if this is related or not.....but for the last couple of days the indicator lights on the Core and the M5 have been red. After the update to the M5 the light is now the normal color. The Core is still red. The core is working fine even with the red light on, unless I join the V1 to it.
Does anyone know a release date for the new software?
My M3 is on 1.4.26906.6752509 and still I can't multiroom to my televisions (which hurts because my setup is currently M3 + V1 + V1).
