Further Software problems AVANT and multi room
This post has 26 Replies | 3 Followers
David Coyne
Sydney, NSW, Australia
Posts 305
David Coyne Posted: Sat, Dec 15 2018 4:22 AM
Hello
For over two years now I'm been plagued by software problems with my various bang and olufsen products, including the beosound 5, moment , beoplay 1. This necessitated various correspondence with Denmark. After multiple requests a teleconference with Denmark was set up and my moment worked for about 6 weeks without any issues. Short version, stopped working properly and I took the product back for a refund.
My latest issue is with my Avant 55 Mk 1 (which is still less than three years old and under warranty). My Avant is integrated with a CORE using the B&O app to access NAS, TuneIn and Deezer.
The issues now are:
1. Music will not play via Avant and connected speakers for more than an hour without switching off (we've checked timers and its nothing to do with that).
2. If the avant/ core is joined with other multi room products music starts to cut in and out and is not useable.
Technicians have visited a couple of times and suspected a software platform fault. They have spent hours and hours testing all equipment.
I've emailed Denmark about this several times, I've not received any response at all. Just silence.
The technicians participated in a teleconference with Singapore team to discuss. Singapore confirm it is a software platform issue that is incompatible with other products.They don't know if an update will be coming for the Avant Mk1 (even though my TV is only 2.5 years old and bought new from the show room).
A work around is to connect my beolabs directly to the core, though this will mean i can no longer have my speakers work with the TV.
Im tempted to try and return the TV and the electronic wall bracket and ask for a refund.  Interestingly just called the only Showroom left in the country who suggested that if I can watch tv then there's no issue and there are possibly no grounds to suggest  refund!
Any suggestions? I've run out of patience with the ongoing software issues.
David
Beovision 8-40, Beocentre 6-26, Beocentre 2, Beolab 9's, Beogram 7000, Beogram 9500, Beo 5, Beolit 1000, 800, 700, 600, 400, Beocom 6's, Beotalk 1200
Aussie Michael
Melbourne, AU
Posts 3,730
Hi David.
I feel your pain. Have been there. My Avant gen 1 is just now 4 years old today and it failed with 1080p vision.
Service says that the part should arrive shortly but it’s at my cost (not warranty).
Is the core directly plugged in to the Avant or is it wireless ?
If wireless what are your settings for delay ?
Your Avant does have all the stations from tune in on net radio and it has deezer. Deezer on my Avant in Melb does not work (not sure if yours does there). It also has access to your NAS on home media.
What I’m getting at is can you live without the core ? I am not saying you should - just wondering.
Your Avant should be able to join muktiroom instead of the core on the app and or remote probably without the core.
I have an essence integrated with the BV14 only cos I didn’t have a need for it and definitely see why you have integrated the core with your Avant. I mean deezer is probably way quicker and it probably works and you could use two way control of you had a BeoRemote One BT edition.
I’ll take another good read of your post a bit later and see if something else comes up in my brain.
Do you have the BeoTool app ? Is the core showing as “integrated”
Cheers from wet Melbourne
M
Razlaw
Posts 4,345
Razlaw replied on Sun, Dec 16 2018 5:24 PM
I recently purchased a Core. Also have an Essence MK2 and a V1. I also experienced the cutting out of sound when joking the V1 yo the group. Today I played around with the settings on the V1. The three products are in three different rooms. I went in to the “link” settings of the V1 and linked it to the Essence and the Core. Also selected not in the same room in the V1 settings. It seems to have solved the problem and all seems to be working now.
w5bno123
London
Posts 578
w5bno123 replied on Sun, Dec 16 2018 5:38 PM
I believe there is a software issue post Apple Airplay 2 update and a new version is coming soon.
vlohjr1
Posts 553
vlohjr1 replied on Sun, Dec 16 2018 7:12 PM
Razlaw:
I experience the same as wellUnsure
Razlaw
Posts 4,345
Razlaw replied on Sun, Dec 16 2018 7:32 PM
vlohjr1:
Razlaw:
I recently purchased a Core. Also have an Essence MK2 and a V1. I also experienced the cutting out of sound when joining the V1 to the group. Today I played around with the settings on the V1. The three products are in three different rooms. I went in to the “link” settings of the V1 and linked it to the Essence and the Core. Also selected not in the same room in the V1 settings. It seems to have solved the problem and all seems to be working now.
Since changing the settings in the V1, all three systems have been playing for a couple of hours with no problems.  Have also tried turning on and off repeatedly. At least in my system, it seems that I may have solved the problem.
Millemissen
Flensborg, Denmark
Posts 14,680
w5bno123:
Can you confirm this?
I haven’t updated my Essence (yet) - I won’t need AirPlay 2 there anyway.
But I occasionally do need to redirect something airplayed to my tv’s (the NL function).
This works very well - in fact all works well.
P.S. My Essence is connected to my two tv’s....not integrated with.
So - if there really should be a problem there (with the latest update), I guess I’ll wait a while with updating (or don’t do it at all).
mikewalsh
Posts 13
mikewalsh replied on Sun, Dec 16 2018 10:30 PM
I have the same issue as you David, the Airplay 2 update has broken the multiroom functionality with the Avant Series 1. I have a Moment integrated with the Avant, but even when I take this out, the TV also can't connect to the multiroom stream without cutting out. For some reason, if you initiate the stream from the TV, rather than another room - it seems to work.
Let's just hope that Denmark choose to update the software, but given that the last update was in mid 2017, I'm now a bit worried about the longevity of the Avant platform.
Dion
Perth, Australia
Posts 47
Dion replied on Mon, Dec 17 2018 3:59 AM
Hi everyone,
I can also confirm, post AirPlay2 update of my A9, A6, and M5 I have the same issues.
If I play something using the B&O app to either the A9, A6, M5 and then join in with the Avant gen1 the sound cuts in and out. If I am playing something on the Avant (TV, HomeMedia...) I can join in the other items with no issue.
I also have a BeoSystem4 connected to a projector and it behaves the same as the Avant, in other words, it affects all BeoSystem4 platforms.
Not great timing for the Christmas holiday and party season!!! Here's hoping for a quick resolution to this one...
BeoVision Harmony77 G1 with BeoLab18 x 4 & BeoLab14 4.1 (7.1.4); BeoPlayA9 Mk4; BeoSound2; BeoSound1 x 2; BeoPlayH95; BeoPlayE6; BeoPlayH3 ANC
..and it all started 20 years ago with a pair of B&O A8 Earphones...
1990
Posts 521
1990 replied on Mon, Dec 17 2018 7:00 AM
Same here with my V1. After maybe 20 minutes or so the trouble starts. Have contacted BeoSupport which recommended cutting the V1 off power for a night. Didn't help.
Millemissen
Flensborg, Denmark
Posts 14,680
It seems that they have to do some overtime work correcting this sw in the next few days - glad I did not update my Essence yet 😉
Dion
Perth, Australia
Posts 47
Dion replied on Sat, Dec 29 2018 2:50 AM
Just an update for everyone...this is still not fixed so I have been in contact with beoplay/beocare. Unhelpful as always, refusing to acknowledge that it is an issue with the lastest software and telling me it is a BeoSystem problem. As a last resort I asked if I could have the software in my A9 A6, M5 rolled back for the Christmas break but they said this was not possible...so annoyed!!!
Yendys
Sydney
Posts 312
Yendys replied on Sat, Dec 29 2018 8:28 AM
This is very very poor I feel for ever one affected by the recent update and the responses you have received. Sad
As I’ve read so so many software related issues I have decided that when my BV10 and 8 fail they will not be replaced by a B&O TV after over 25 years of BV ownership.
w5bno123
London
Posts 578
w5bno123 replied on Sat, Dec 29 2018 1:36 PM
There is a service solution for audio systems available now, request it via your dealer. Expect the general release to rollout first few weeks of January.
David Coyne
Posts 305
Hi Yendys
At least you received a reply, some two months on after sending an email to BeoCare, positing on their facebook page and sending a message via messenger, I've received no reply at all.
What used to be a premium brand now rather behaves like a secretive government agency providing no responses and admitting no liability. If you don't respond the problem doesn't exist.
As more time goes by I become more and more infuriated with the lack of care and responsibility.
I know there are software problems, they just have to say so! Clearly the strategy of bringing software back in house has had limited success. Clearly the multi room functionality seems to only work now if you have a couple of products all of the same generation. If you start combining more than a couple of products the system and software seems unable to manage. The whole point of staying with the brand was seamless integration, not weekends of endless resetting of products, deleting of products, developing 'work arounds' , all to be able to listen to an album!!
I've recently given away my Beosound 5 with a 1TB and CD ripper because it was unsellable. I took my Moment back due to software problems, now the TV that is still under warranty isn't working properly. AS the TV still functions as a 'TV' though there is 'no problem' as far as B&O are concerned. If I had a more up to date TV they say it would be all ok! Seriously I'm going to spend 15k on a TV when my old one is still under warranty?!
Happy New Year!
David
Dyssegaard
Copenhagen, Denmark
Posts 263
w5bno123:
I have just now updated my M5 to version 1.18.27862.189486813 available in the B&O app today.
Hopefully that will fix the problems I had with sound dropouts on my BV11/Core when playing Spotify and nl multiroom to my M5. I will test it the next few days.
Best regards - Dyssegaard
Living room: Beovision Eclipse 55, Beolab 3 / R1 (back), Beolab 2 / R1 (sub), AppleTV 4K. Bedroom: Beovision 11-40, AppleTV 4. Home office: Beoplay M5. Kitchen: Beoplay M5. Travel: Beoplay H8, Beoplay A1. NAS: WD My Cloud Home / Plex DLNA Server.
Brian
London/Aarhus
Posts 219
Brian replied on Wed, Jan 9 2019 7:47 AM
David,
Try hard wiring the core & Avant rather than wireless. I have been having major drop out issues with my BV11-55 when joining it to multiroom music. It would play ok for 30 min or so when joined to ONE other product before drop outs began - and if I attempted to join any more products it would drop out instantly.
Yesterday I plugged in the BV11 with an Ethernet cable and it does seem to have resolved the constant intermittent drop outs. Additionally I can now join further products to the network :-)
Furthermore, I have a Core, also hardwired, running a BL11 & BL8000s in my dining room and it never plays up or drops out.
Aussie Michael
Melbourne, AU
Posts 3,730
I have found great success with hard wiring , but that may not be that easy for all people
1990
Posts 521
1990 replied on Wed, Jan 9 2019 11:24 AM
Too bad that hard wiring won't be a fix for the M3
Razlaw
Posts 4,345
Razlaw replied on Wed, Jan 9 2019 1:46 PM
I have been having the same issue with my V1, Core, Essence, and M5. After yesterday’s software update to the M5 everything seems to be working as it should, if I start with the M5. Joining the V1 to the already playing M5 has worked with no problems. Hopefully the same software fix will soon come for the Essence and Core.
Also, don’t know if this is related or not.....but for the last couple of days the indicator lights on the Core and the M5 have been red. After the update to the M5 the light is now the normal color. The Core is still red. The core is working fine even with the red light on, unless I join the V1 to it.
Hiort
Sweden
Posts 2,895
Hiort replied on Wed, Jan 9 2019 2:43 PM
Razlaw:
What is the latest version of the M5 software?
Do you know what the update included other than bugfixes?
Razlaw
Posts 4,345
Razlaw replied on Wed, Jan 9 2019 3:47 PM
I don’t know what all the update included. Will check the version number later.
Razlaw
Posts 4,345
Razlaw replied on Wed, Jan 9 2019 10:35 PM
1.18.27862.1894486813
Dyssegaard
Copenhagen, Denmark
Posts 263
Razlaw:
When I start TuneIn on my updated M5 and later on join my BV11 everything seems to be ok.
However, if I start TuneIn on my Core (integrated with the BV11) and then join the M5, sound on the BV11 starts to drop out after a couple of minutes. The strange thing is, that the M5 continues without any drop outs.
So I’m also looking forward to get the update for the Core.
PS. Indicator lights are normal on both my M5 and Core.
Razlaw
Posts 4,345
Razlaw replied on Thu, Jan 10 2019 5:54 PM
I rebooted my wifi system and now all indicator lights are normal, so that issue appears to have been wifi related.
Dyssegaard
Copenhagen, Denmark
Posts 263
I visited my local dealer this afternoon, and based on the serial number he could push a hotfix (1.3.27802.28672131) to the multi room problem to my Core.
The update was available when I got home.
My BV11/Core and my M5 have now been playing Spotify via the Core for more than an hour without any problems. That was not possible before the hotfix, so I think that the problem is solved Big Smile.
PS. My dealer said that the update would probably be generally available later this week.
1990
Posts 521
1990 replied on Fri, Jan 25 2019 12:01 PM
Does anyone know a release date for the new software?
My M3 is on 1.4.26906.6752509 and still I can't multiroom to my televisions (which hurts because my setup is currently M3 + V1 + V1).
Page 1 of 1 (27 items) | RSS
