Beomaster 7000 Easy fix?
This post has 5 Replies | 0 Followers
DMacri
United States
Posts 881
DMacri Posted: Thu, Dec 20 2018 10:38 AM
I just bought a very nice looking BM7000, but when plugged in shows all the display inputs lit up rather than standby as expected.
Is this an easy fix, or an indication of a much more significant problem?
Dom
2x BeoSystem 3, BeoSystem 5000, BeoSystem 6500, 2x BeoMaster 7000, 2 pair of BeoLab Penta mk2, AV 7000, Beolab 4000, BeoSound 4000, Playmaker, BeoLab 2500, S-45, S-45.2, RL-140, CX-50, C-75, 3x CX-100, 3x MCL2 link rooms, 3x Beolab 2000, M3, P2, Earset, A8 earphones, A3, 2x 4001 relay, H3, H3 ANC, H6, 2014 Audi S5 with B&O sound, and ambio
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Thu, Dec 20 2018 11:08 AM
Probably a dead processor and/or/because of power supply failure.
Overvoltage from lightning strike or wrong mains voltage setting perhaps.
Easy? - Depends on how much has burned.
LIghtning strike cases usually means write-off for these models.
- But it could also be as simple as too much ripple on the CPU voltage.
It will have to be diagnosed to know why and how much.
I would start at the low-voltage regulators.
If you bought it as working, I suggest you return it.
DMacri
United States
Posts 881
DMacri replied on Thu, Dec 20 2018 1:13 PM
Thanks Martin, I did buy it from eBay in working condition. I will sadly have to send it back.
Dom
chartz
Burgundy, France
Posts 4,171
chartz replied on Thu, Dec 20 2018 1:21 PM
I had that on a 5500 (after years of faultless service) and I found yet another bad cap on the processor board that I had forgotten under the lid. Worth a try methinks!
That said, you could get a partial or total refund if the said working unit was DOA, and get to keep the Beomaster.
Jacques
Dillen
Posts 13,191
Dillen replied on Thu, Dec 20 2018 4:38 PM
Don't attempt repairs yourself, if you are planning to return it if it fails.
DMacri
United States
Posts 881
DMacri replied on Thu, Dec 20 2018 6:39 PM
Martin, I’m contacting the seller to work on a return. I’m not going to mess with it. Shame too, it’s in great cosmetic condition.
Dom
Page 1 of 1 (6 items) | RSS
