Dom
2x BeoSystem 3, BeoSystem 5000, BeoSystem 6500, 2x BeoMaster 7000, 2 pair of BeoLab Penta mk2, AV 7000, Beolab 4000, BeoSound 4000, Playmaker, BeoLab 2500, S-45, S-45.2, RL-140, CX-50, C-75, 3x CX-100, 3x MCL2 link rooms, 3x Beolab 2000, M3, P2, Earset, A8 earphones, A3, 2x 4001 relay, H3, H3 ANC, H6, 2014 Audi S5 with B&O sound, and ambio
Probably a dead processor and/or/because of power supply failure.Overvoltage from lightning strike or wrong mains voltage setting perhaps.
Easy? - Depends on how much has burned.LIghtning strike cases usually means write-off for these models.- But it could also be as simple as too much ripple on the CPU voltage.It will have to be diagnosed to know why and how much.I would start at the low-voltage regulators.
If you bought it as working, I suggest you return it.
Jacques
Don't attempt repairs yourself, if you are planning to return it if it fails.
