hi uk beoworld hope someone knows the answer to my problem.
my sky+ hd box packed up so had to get a new one any way if i use the sky remote tv guide works perfectly no problems. if i use beo4 or my beo5 scroll down the list select the channel i want eg sky sports or sky 1 and it opens in planner everytime.
anyone know what i need to do, my tv is a beovision 10-40 it has the latest software
at the moment no dealer here hence my question in beoworld
malcolm
There has been a new Sky+HD set of codes released for the PUC list in your TV. I can't remember the exact differences but your new box would ideally be used with the latest B&O PUC software.
Opman
I have to hit the go button quickly twice to select , one press on the go will bring up the planner , even when watching a program one press on the go brings up the planner .
hi guys thanks for your replies technician downloaded all updates doing twice on go rapidly still defaults to planner.
had reply from denmark sky tv box amstrad drx890-r not in puc list. as this is standard issue for sky+hd in the uk would have thought it would have been added already. have to ask uk or any dealer to request it be listed. thought the uk national office would have a lot of requests for this to be done
oh well keep chasing
denmark states not listed dealers need to ask for it to be listed then can be added by denmark and downloaded,
seems a funny way round
Malcolm, get them to put "Thompson SkyHD Mk2" in the PUC. That works fine with the 890/895.
David (BV8-40)
hi guys
ok set box stored thompson hd mark 2, press menu 1 nothing happens no tv guide or anything. use sky remote brings up tv guide if i use beo4 or beo5 now canscroll through programmes but imediatly select a channel opens in planner . how would beo4 with navigation tool help. driving me mad as no dealer at present. spain confirm any sky box hd in puc list should work.
to have 890 listed 500 euros
Help
fingers crossed madrid might be paying for it to be listed, but still intrigued how new beo4 would be better
many thanks downloaded software again still goes to planner when selecting a channel
hopefully get sorted out
hi martin
many thanks for the info will get the technician to bring one next week, will keep you posted
