Hi all,
I have a Beocenter 2 in my main room, this is connected to my Beovision 8 32 in the Kitchen (via masterlink). I can get the radio and cd etc from the Beocenter to paly in the kitchen, but does anyone know how to get the A.Aux which I have my non B&O turntable connected to, to play in the Kitchen I have two Beo4 remotes both MK3 I believe one in the room and one for the Beovision in the Kitchen.
You should be able to add A.AUX to the LIST function on the Beo4, hence be able to select in the kitchen.
To add it, on the Beo4:
- Press Power and LIST together, the display should read ADD?
- Press GO.
- Press LIST until the display shows A.AUX. then GO.
- A.AUX should then be listed under LIST.
Thanks for the reply Guy, that worked prefect
Regards
Gary
Great news - now you can listen to your turntable whilst you cook Xmas Dinner!
