A.Aux From Beocenter 2 to Beovision 8 (link room)
This post has 3 Replies | 0 Followers
gadmin
Posts 36
gadmin Posted: Sun, Dec 23 2018 2:20 PM
Hi all,
I have a Beocenter 2 in my main room, this is connected to my Beovision 8 32 in the Kitchen (via masterlink). I can get the radio and cd etc from the Beocenter to paly in the kitchen, but does anyone know how to get the A.Aux which I have my non B&O turntable connected to, to play in the Kitchen I have two Beo4 remotes both MK3 I believe one in the room and one for the Beovision in the Kitchen.
Guy
Warwickshire
Posts 2,590
Guy replied on Sun, Dec 23 2018 2:46 PM
You should be able to add A.AUX to the LIST function on the Beo4, hence be able to select in the kitchen.
To add it, on the Beo4:
- Press Power and LIST together, the display should read ADD?
- Press GO.
- Press LIST until the display shows A.AUX. then GO.
- A.AUX should then be listed under LIST.
gadmin
Posts 36
gadmin replied on Sun, Dec 23 2018 3:02 PM
Thanks for the reply Guy, that worked prefect Big Smile
Regards
Gary
Guy
Warwickshire
Posts 2,590
Guy replied on Sun, Dec 23 2018 3:51 PM
Great news - now you can listen to your turntable whilst you cook Xmas Dinner!
Page 1 of 1 (4 items) | RSS
