Hi
Just received this unit and when pluging in the unit the clamper opens, the cd lids lift and then closes then opens again but only half way and stays there.
I did not checked yet the service manual.
Looks like the unit does not know where the clamper state is or may be a worn belt that is not able to open the clamper full way or else.
Just posting in case someone had the problem and would speed up my repair search.
Happy holidays to all you B&O passionates.
Hello
maybe the belt of the cd-unit have to be replaced
Ingo
BeoVision Eclipse 55“ wallmounted, BeoRemote One BT; BeoSound 9000(ex-weiss), BeoLab 9; BeoLab 8000 rot; Beosound 1 grün; BeoPlay H6; Beo4
I speak about unit-Nr.: 9009; 2732004
The belt his most weak after several years
Check out the service manual
Change the belt for the clamper and check lubrication on the gear where the belt is attached. The belt incl the belt wheels must be free of dirt and grease.
Hi all
Thank you for your replies
I opened the unit and guess what ? someone tried before me and ripped the smd connector of the left clamper.
Some guys should not touch expensive goods like this and keep fooling around repairing their kids toys.
Will keep you posted if resoldering the connector stops the opening and closing behavior.
Lucky the connector is not broken and I will be able to re-solder the SMD connector.
Hi all, I have the same issue with beocenter 2, any idea where I can buy the 2732004 belt? I've emailed a few places but i'm not getting any replies. I guess they don't have it?
Beolab 8000 x 2
Beolab 1
Beolab 2
Beovision 7-40
Beosound 9000
Beosound Ouverture
Beolit 12
The belt in my BC2 is also on its way out.
I also e-mailed some places and got no response.
Maybe someone has info on the dimensions of the belt ?
How big of a job is it to change the belt?
